Home > General > 2010 Sport Steering column locked & vehicle wont start. |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
is it keyless entry ? |
Tue Oct 07 2014 4:34pm |
Kidneywiper Member Since: 07 Feb 2011 Location: England. Posts: 16 |
Yes, keyless entry. |
Tue Oct 07 2014 4:36pm |
probably battery going flat on your key
Tue Oct 07 2014 4:38pm |
All new batterys fitted in both keys. Still no better. |
Tue Oct 07 2014 4:40pm |
do you get an error message saying key out of range or not found etc ? |
Tue Oct 07 2014 4:43pm |
The only message showing is steering column locked. |
Tue Oct 07 2014 7:55pm |
may be an idea to see if any fault codes are showing and do a "hard reset" |
Tue Oct 07 2014 9:24pm |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 |
Try moving steering wheel slightly side to side while pressing the start button ,sometimes the steering wheel is to tight and the steering lock jams . |
Sat Oct 11 2014 11:42pm |
Needed a new instrument pack to cure the problem. Known fault with a L/R bulletin to go with it apparently ! ! |
Mon Oct 20 2014 7:25pm |
peterg1965 Member Since: 20 Sep 2014 Location: Lancashire Posts: 81 |
How much did that cost? Range Rover - 4.4SDV8 Autobiography - Corris and Black
Tue Oct 21 2014 1:14pm |
£450 for the intrument pack & 2hrs labour cost at the dealer plus vat. |
Tue Oct 21 2014 1:39pm |
Blimey, that must have hurt. Range Rover - 4.4SDV8 Autobiography - Corris and Black
Tue Oct 21 2014 8:16pm |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
Anyone knows the bulletin number? |
Wed Oct 22 2014 11:08am |
diamond71 Member Since: 24 Nov 2014 Location: horsham Posts: 25 |
would be great to get that bulletin number, I have the same problem 2010 model |
Mon Nov 24 2014 4:58pm |
