![]() | Home > Faults & Fixes > Boot! Glass part will not open |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Have a look here mate
Wardie Member Since: 08 Oct 2014 Location: Birmingham Posts: 6 ![]() ![]() |
hi
Hi, best way to avoid any damage is to take off the rear trim panel completely then you have great access to the switch. Be prepared for a shock at seeing all the rust and crud under there though.
hi
Did you try checking the microswitch for continuity? It is quite common for it to fail as water gets in. A complete replacement unit only costs about £17 from Land Rover so worth a try. 2008 MY Java Black TDV8 HSE
hi mate
Hi, not sure if you mean it looks OK or if you actually checked it with a multimeter. It's quite a big unit but the circuit is controlled by tiny microswitch tucked inside. Definitely worth changing it for the modest cost and if that doesn't fix things then look a bit further? 2008 MY Java Black TDV8 HSE
I didn't do any tests on the microswitch, what ill do is change the switch and go from there
R8BHX Member Since: 11 Oct 2014 Location: Essex Posts: 8 ![]() ![]() |
I got this problem to now? I changed to unit after a few mins of playing around getting it out with no damage but still nothing? Any ideas is there a fuse for it |
Hi ya
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Easy way to check if its the switch,unplug the switch you will be left with a female connector on the car,get a small piece of wire insert into the connector thus making a circuit,if the glass opens you then know it's the switch. |
I changed to switch but still nothing is there a fuse just for it? Or can I test for power anywhere ? Don't forget the glass is closed so not much I can do if I need to open it? |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
I had this problem too, changed the switch but still didn't work. The third button in my spare key opens it so the powered lock on the main boot side works. Apparently the wiring that goes from the switch, round the window and back round in to the main boot to the lock gets corroded and fails. Looks like I'll have to root a new wire in to fix it, or just live with it! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
