Home > Technical > rr sport tdv6 high pressure fuel pump
scott1963
does the body have to come off to replace the hp fuel pump
Post #437093 Fri Sep 19 2014 5:09pm
It's in the V at the back of the engine, driven by the LH exhaust camshaft. According to the workshop manual it's done without removing the body. It needs a new belt and tensioner when the pump is removed. 2012 SDV6 - it's missing a couple of cylinders
Post #437100 Fri Sep 19 2014 5:53pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
fairly straight forward, i find the breather assembly the hardest part of the job! theres always one boly you cant get to unless you take something else off (the engine breater) lol
Post #437103 Fri Sep 19 2014 6:22pm
Disco_Mikey
No it doesn't. Done loads of them Thumbs Up
Mostly done blind, but that breather is a Censored
Post #437115 Fri Sep 19 2014 7:28pm
stealth
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Phew
Post #437141 Sat Sep 20 2014 10:25am
