![]() | Home > General > extreme wobble when braking ##please help~~~ |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
Bodsy did a great guide to changing discs and brakes worth a read
m40cca Member Since: 04 Sep 2014 Location: leeds Posts: 89 ![]() ![]() ![]() |
thanks for that but the link wont work! |
anyone else have an idea what it could be?? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Try the link under Bodsys profile |
Just set off back home and the first 20mile of driving on normal roads as soon as we have got on mway where I'm using brakes more and a little higher speeds the wobble has started again!!
Check calipers first as you may have a seized one that causing the heat.
I did have a seized caliper bottom pin when I checked them before but I think the discs are just shagged!!
If the caliper pin is stuck, then you can give them a real good clean and as long as they are not pitted, should be fine with some hi temp silicon grease. DON'T use copper grease on the calliper pins as they get sticky and will cause you a bigger problem.
just for info, I went with LR genuine disks and pads and have used aftermarket pads on genuine disks with no problem. my personal experience is that the aftermarket disks aren't as good as the LR disks. Whether that is perception or a technical reality, but I found the LR disks more stable when 'heavy braking' |
Bodsy just read your brake bible and I never bedded my rear discs in like you say with the parking brake is that a problem?
no, I doubt that's the problem. It shouldn't affect the wobbling. Have you taken the disks back off, wire brushed all the contact points on the hub, then replaced it all? Bodsys Brake Bible
Yes done all that, the weird thing is on my way home from London today I got the hdc fault code thrown up with the various orange suspension light, traction light and handbrake light under the temp gauge, I haven't had time to pull off and reset with key, but very weirdly the car is braking fine with no steering wobble and honestly the brakes feel the best they have ever been
Take that back it's just as bad just braked hard for a wagon and it's wobbled really bad |
Bodsy can't seem to find the v8 upgrade on advanced factors found the brembo discs and pads at £145 which look a good price |
