![]() | Home > Technical > 05 Range Rover Sport Tdv6 SE starts then stalls |
monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28 ![]() |
No worries mate. Is yours fine in the Summer months?
Claus1949 Member Since: 14 Dec 2013 Location: Marhsfield Posts: 4 ![]() ![]() ![]() |
I have just done 2 clean ups of the injectors, 2 full tanks with the cleaner, and since I have no problems starting. |
I am afraid to say that the problem has reoccurred. Was starting for ok for about 5 days now it's back to starting then immediately stalling after. Resulting in a hard start with lots of cranking. |
Gilly Member Since: 22 Jan 2014 Location: Notts Posts: 3 ![]() ![]() ![]() |
New to this please forgive me if I sound a little thick
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
hi mines doing the same did anybody find the cure thanks in advance |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Hi
will check it out thank you |
Hi thanks for that, will check it out, did suspect air getting into fuel line but most garages spoke to think it was the low pressure pump on its way out but not sure |
Had a look round and vale doesn't appear to be leaking, über the last month or so started to miss a little on start up, but not stalling, |
