Home > Technical > 05 Range Rover Sport Tdv6 SE starts then stalls
monkers2003
Hi
Yesterday I tried starting the car and it fired up for a second then it cut out. It had been a cold night and this was in the morning. I tried again and after 4 times with accelerator peddle push it started,
Once the car is warmed up it starts fine and has been fine all summer etc.
Any suggestions?
Its had a new battery last month as well
Post #402533 Sun Nov 17 2013 5:41pm
Paddi
Could it be some of the glowplugs faulty? Would a diagnostic check with a suitable fault code reader help to pin point the problem? According to other posts on the forum getting the glowplugs out is a real 'beeatch' to do so if it proves necessary make sure you take it to someone with lots of experience with this job on this engine. 2008 MY Java Black TDV8 HSE
Post #402541 Sun Nov 17 2013 6:04pm
monkers2003
I'm not sure. Ive heard MAF sensor and ecu temp sensor issues could be causing a problem.
I know a land rover technician who said it could be a clogged injector and said to put some injector cleaner through the system.
I am going to take the car there tomorrow and have it plugged into the diagnostics
Post #402544 Sun Nov 17 2013 6:10pm
Paddi
Thumbs Up don't forget to post up the results. If it was an injector fault though wouldn't it run badly all the time not just be hard to start? 2008 MY Java Black TDV8 HSE
Post #402559 Sun Nov 17 2013 7:10pm
monkers2003
Yea will do. Well it sometimes runs a little rough at idle. And I do remember a couple of months ago a diagnostics check showed cylinder 5 misfiring.
Post #402562 Sun Nov 17 2013 7:21pm
Disco_Mikey
Glow plugs or injectors Thumbs Up
Post #402571 Sun Nov 17 2013 8:08pm
adigorn
or HP Pump Thumbs Up
Post #402575 Sun Nov 17 2013 8:34pm
Disco_Mikey
Not convinced, but these cars are strange beasts. Could be a brake light bulb Laughing
Post #402638 Mon Nov 18 2013 6:50am
adigorn
Quote:
Not convinced
wasn't making it up speaking from experience Thumbs Up
Post #402755 Mon Nov 18 2013 9:00pm
monkers2003
Just an update, the cars going to land rover today and they are keeping over night to see how it starts in the morning. It took a while to start this morning as it was around +1 degrees.
I will post tomorrow with an update
Post #402785 Tue Nov 19 2013 9:16am
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
Get them to check the O rings on the fuel pipes mate some times they wear down and start taking air in.
Post #402798 Tue Nov 19 2013 1:11pm
Big Dave
I'll be interested in what they say on this, I had an identical issue with my SC and found it to be a low battery. Now I put it on the C-tek once in a while and I've not had a problem since. 2011 Evoque Si4 Dynamic plus lux
2007 Audi TT 3.2 V6
2005 Sport Sc
Post #402916 Wed Nov 20 2013 3:09pm
Claus1949
Hi
what was the outcome of your diagnostic, I have a similar problem with my RRS
Post #406172 Sat Dec 14 2013 6:34pm
monkers2003
Just an update on this.
I took this to Land Rover and the diagnostics showed no problems. Typical.
The car struggled to start this morn at 2 degrees. Started then stalled a second later.
Took 4 more times and 5 mins later to start and some gentle revving for a few minutes I was able to get to work!
Post #406499 Tue Dec 17 2013 4:16pm
Claus1949
thanks for that, just wondering what's causing this problem. Mine started first time today, but stalled yesterday.
Will keep you informed if I come up with a solution
Post #406501 Tue Dec 17 2013 4:38pm
