Home > For Sale & Wanted > [For Sale] Brand new rear LED tail lights
Disco_Mikey
I have for sale 2x sets of brand new LED tail lights
�325 per pair. Delivery is an extra �8 via 24hr courier
Do not come with resistors for pre-2010 models, but can supply at an extra �6 for a pair
Post #430557 Tue Jul 15 2014 9:20am
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
They Hawke type? Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #430567 Tue Jul 15 2014 10:09am
Disco_Mikey
No, these are OEM lamps.
Post #430568 Tue Jul 15 2014 10:11am
Mr Crabtree
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
I am learning?
I thought the resistors were built into the lamps? Working with Virgin Trains and band of Brothers/Sisters to do something special for our injured servicemen and women
Post #430573 Tue Jul 15 2014 10:32am
Disco_Mikey
The early models had filament bulbs, which drew 21W from the circuit when the indicators are switched on.
The LED's only draw around 2.5W, so the car thinks there is a blown bulb, due to the low current.
The LED's still flash as the same speed, but the warning lights on the dash flash fast, to tell you there is an issue.
The resistors put a load into the circuit, so the car is still drawing enough current to cancel out the warnings
The 2010MY's were developed with LED's in mind, and so do not need resistors, only the 05-09MY's need them
Hope that helps Thumbs Up
Post #430574 Tue Jul 15 2014 10:36am
Mr Crabtree
Your a star and thanks for the information
a very good price indeed. Smile Working with Virgin Trains and band of Brothers/Sisters to do something special for our injured servicemen and women
Post #430575 Tue Jul 15 2014 10:37am
Disco_Mikey
I have been a site sponsor here for 6 months now, and have been neglecting this site somewhat, for Disco3 Embarassed
Time to make up for that Thumbs Up
Post #430577 Tue Jul 15 2014 10:51am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Mikey, can you help, I bought these http://www.ebay.co.uk/itm/261458919405?ssP...1423.l2649 and they don't appear to be the correct ones, the light flashes ok but the indicator on the dashes still flashes fast. Can you supply a correct one with some wire soldered on either side? Bow down Bow down
Post #430589 Tue Jul 15 2014 12:01pm
Disco_Mikey
How have you connected them into the circuit, in series or in parallel?
If they are the wrong way, what you describe will happen
Post #430590 Tue Jul 15 2014 12:04pm
1JBS
Thanks Mikey I have clamped them onto the wires but wasn't aware that there was a correct way round for the resistor, are they the correct rating at 50 watt 6 ohm ?
Post #430605 Tue Jul 15 2014 1:50pm
Disco_Mikey
The resistor can be either way round, it doesn't matter.
What does matter is if it is wired in series or in parallel.
I hope this picture makes sense, albeit, using 2 bulbs:
Imagine the right hand "lamp" is your LED, and the left hand "lamp" is the resistor.
It won't work if the resistor is in line, it has to be placed across the circuit to load it up
Post #430608 Tue Jul 15 2014 2:27pm
1JBS
It is loading because it gets hot when you put the indicators on...is it the right size resistor ?
Post #430630 Tue Jul 15 2014 6:12pm
Disco_Mikey
But if the resistor is not connected into the circuit correctly, it will get hot, and appear to be working OK, but doing nothing...
Lets assume your resistors are fitted incorrectly. If I send you another pair of resistors, and they are fitted the same way, they will do exactly the same as yours are now. The resistors I use are also 50W
We need to establish whether the resistors have been fitted correctly in the first instance...
Post #430667 Tue Jul 15 2014 10:04pm
drdelrrs
Perhaps this might help....
The resistor must have one side fed from the same 'live' feed as the bulb and the other 'side' connected to earth in the same way as the light unit earths. In other words it bridges the bulb circuit.
I apologise if I'm teaching "granny to suck eggs".
Post #430669 Tue Jul 15 2014 10:14pm
