Home > Maintenance & Modifications > Performance Air Filter
Page 4 of 5 <12345>
Biggles
Air Filter turned up yesterday. I fitted it myself last night very easy to do just six screws to loosen and lift and remove old filter and replace new.
I was suprised how dirty the original filter was but I have driven on quite a few dusty sites before winter started to set in. Which does prompt me to think i will service the car in our workshops before the stated 15,000 miles or 1 year as per landrover instructions. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #4144 Fri Oct 28 2005 8:58am
I have just had an email reply from ITG - details below :-
http://www.itgairfilters.com/
Hi Martin,
Sorry for the slow response, I’ve been working on various projects over the last few weeks and have only just started working through the backlog of e-mails – you were actually 5 e-mails away from a response when this enquiry came through.
We do have a panel filter available for the new Range Rover Sport, our HMP-372, these are available at a cost of £39.00 + vat and can be bought direct from ourselves (we’re based in Coventry).
We don’t actually make any claims for increased performance from our panel filters as the gains usually found can be quite small, however most of our customers report that the engine seems to run more freely and I have noticed (in my Nissan Primera) a slight increase in low down torque as well as being able to rev the engine a little harder without it feeling strangled. Another point raised by customers is that they generally see an extra 1-2 miles per gallon using our filters, the Primera generally does an extra 30 miles or so per tank full when doing longer journeys but I haven’t really noticed much difference around town.
Another advantage with our filters is the way they trap and hold the dirt, paper filters only hold dirt on the surface of the filter, this means that after a short while the airflow will start to decrease quite rapidly. Foam filters on the other hand trap dirt using the depth of the filter and can therefore hold a lot more dirt without losing airflow; this means you will not get the same drop off in performance between services that you would normally find with a paper filter.
If you would like to purchase a filter please contact me on the number below and I will be more than happy to help you out.
Best regards,
Andy Jackson
Parts Manager
Induction Technology Group Ltd
Tel. 02476 305386 Fax. 02476 307999
Post #4156 Fri Oct 28 2005 11:22am
Esoteric
turbochip wrote:
Pls email me direct
Chris@turbochip.com
I have been very busy working on our latest software releases so you will have to bear with me but if you email me direct I will dealw ith your enquiries
Thanks
Hey Chris,
Any word on when a chip will be available for the supercharged RRS???
Post #4188 Fri Oct 28 2005 5:35pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
Apologies to any members for my disappearance....I have been busy developing a diagnostic tuning tool for LR main dealers.
With regard to the air filters we can supply these next day in the UK for £39.00 + p+p
Post #4207 Sat Oct 29 2005 1:21pm
kam100
Biggles, how is the filter running in your TDV6??
Interested in buying one of these for mine, but would be interested to hear of what difference (if any) it makes to the running of the TDV6 engine..
Thanks
Post #4243 Sun Oct 30 2005 4:20pm
LRtuning
We will have a solution for Petrol and Petrol SC RR Sports in 6-8 weeks Wink
Post #4244 Sun Oct 30 2005 4:39pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
TC,
Please define a 'solution', do you mean air filter-wise or chip wise? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #4245 Sun Oct 30 2005 4:41pm
LRtuning
A 'chip' solution no less....petrols use japanese DENSO ecu system but we have found a way to 'crack' it Wink
Post #4246 Sun Oct 30 2005 4:47pm
RRUK
That DOES sound interesting.... L319 D4 HSE
1982 Series 3 SWB
Post #4247 Sun Oct 30 2005 5:17pm
HHHhhhmmmmm ....... Confused
Post #4290 Sun Oct 30 2005 10:38pm
Biggles
Thanks
So far I cant say I have noticed any great difference, But as i said in an earlier post glad I changed it the old one was dirty. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #4298 Sun Oct 30 2005 11:26pm
LRtuning
MDP....what's the hhhhmmm for?
Do I detect doubt in your comment?
We have been working on a 'chip' solution for both LR and Jaguar Supercharged for over a year now....I can already 'flash' original tunes into Jaguar DENSO ecu's and we are doing the same with LR next week.
Once we can work out the checksum issue with the processor in the ecu we will be sorted.
Post #4307 Mon Oct 31 2005 1:31am
RRUK
TC,
If you can give any indication of what improvements or changes it is likely to make that would be helpful.
Are we talking about unleashed power and improved economy? L319 D4 HSE
1982 Series 3 SWB
Post #4316 Mon Oct 31 2005 7:29am
No it was a " Hhhmmm" ,......that sounds interesting - look forward to more details Very Happy
Post #4330 Mon Oct 31 2005 9:04am
LRtuning
We anticipate ann extra 15 bhp on the normally aspirated car and hopefully 30 + bhp on the Supercharged.
I'll keep you all posted Wink
Post #4397 Mon Oct 31 2005 9:49pm
Page 4 of 5 <12345>
