![]() | Home > General (L494) > Gap between door seal and rear bumper |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
The issue is, is that on a £80,000+ car the trim should fit correctly............ |
BRIAN_H Member Since: 07 Jul 2014 Location: Hong Kong Posts: 3 ![]() ![]() ![]() |
I have the same problem, will try to post a pic tomorrow. |
That is the sort of finish you would expect from the likes of Fiat and Lada way back in the 70's |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
You do wonder don't you. You can tell the car in my picture is white by the painted metal showing through the gap. Keep in mind rain will drain down this channel from the top of the car and then down through the gap. I wonder what's behind it... Mark
robot Member Since: 19 Feb 2014 Location: Cheshire Posts: 167 ![]() ![]() ![]() |
Refer to my update 2014/5 rr sport hse, Marianna black , silver roof , silver door mirror caps , privacy , deployable tow bar
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
More plastic? ![]() |
Thought I would try it just poured some water down the gap still waiting for it to come out ????? 2014/5 rr sport hse, Marianna black , silver roof , silver door mirror caps , privacy , deployable tow bar
So it's trapped somewhere. Not good. IMHO, this needs a redesign. Mark
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
That'll explain the fuel tank sloshing noise then |
BTW ref my climate control issues, whereby it suddenly ceases ops, I've now found that above circa 23 deg C ish, if you slam any passenger door, this stops the climate + fan immediately. So, you have to restart the climate from on to off and on again. I guess the sensor is a bit over sensitive, but I'll live with this for now. |
The madness is taking over just shone a pencil torch thru the gap whilst on my back underneath the car and guess what no light showing ????? |
Maybe I should have opted for the gap insurance I wonder if that's what they meant 2014/5 rr sport hse, Marianna black , silver roof , silver door mirror caps , privacy , deployable tow bar
Does this look much worse in the flesh? Doesn't look much of an issue from the pictures... |
No, it looks just as it does in the pictures. Whether it's an issue depends on what your expectations of an £80k car are. Mark
