![]() | Home > In Car Electronics > Just brought my first RRS but need to update the sat nav |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Brought mine off Amazon, worked a treat. LR wanted �160 for the disc so I took my chances with the Amazon one. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Yes, I have an Amazon one too. Works fine. |
Yorkyrrs Member Since: 08 Sep 2013 Location: Sheffield Posts: 3 ![]() ![]() ![]() |
Just bought one from Amazon but am unable to eject the original disc, I have followed the info but disc wont eject, any ideas please ? |
You have moved the slider over to unlock then pressed the eject button ?? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Yes did all that would not eject but read on here that engine needed to be running tried that and worked ok , thanks for the reply. |
If you now have the new one in, and it has updated, you will need to reset the country from the default Belgium or postcodes wont work. |
Done that all appears to be okay, thanks. |
