Home > In Car Electronics > Just brought my first RRS but need to update the sat nav
dazfaz
Im now the proud owner of my first RRS but the sat nav is out of date. Its a 55 plate 2.7 HSE and I wanted to know if there is a particular version of a sat nav DVD that I need. I have seen many different DVD's for many types of Range Rover's which is slightly confusing.
Is there a generic DVD that I can use?
Thanks in advance.
Post #427746 Fri Jun 20 2014 11:46am
martyn05
Brought mine off Amazon, worked a treat. LR wanted £160 for the disc so I took my chances with the Amazon one. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427758 Fri Jun 20 2014 1:02pm
Stuart
Yes, I have an Amazon one too. Works fine.
Post #427770 Fri Jun 20 2014 2:56pm
Yorkyrrs
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Just bought one from Amazon but am unable to eject the original disc, I have followed the info but disc wont eject, any ideas please ?
Post #427776 Fri Jun 20 2014 3:29pm
martyn05
You have moved the slider over to unlock then pressed the eject button ?? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427809 Fri Jun 20 2014 8:39pm
Yorkyrrs
Yes did all that would not eject but read on here that engine needed to be running tried that and worked ok , thanks for the reply.
Post #427812 Fri Jun 20 2014 9:04pm
Stuart
If you now have the new one in, and it has updated, you will need to reset the country from the default Belgium or postcodes wont work.
Post #427814 Fri Jun 20 2014 9:17pm
Yorkyrrs
Done that all appears to be okay, thanks.
Post #427890 Sat Jun 21 2014 6:06pm
