Home > In Car Electronics > Just brought my first RRS but need to update the sat nav |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 |
Brought mine off Amazon, worked a treat. LR wanted £160 for the disc so I took my chances with the Amazon one. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Fri Jun 20 2014 1:02pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
Yes, I have an Amazon one too. Works fine. |
Fri Jun 20 2014 2:56pm |
Yorkyrrs Member Since: 08 Sep 2013 Location: Sheffield Posts: 3 |
Just bought one from Amazon but am unable to eject the original disc, I have followed the info but disc wont eject, any ideas please ? |
Fri Jun 20 2014 3:29pm |
You have moved the slider over to unlock then pressed the eject button ?? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Fri Jun 20 2014 8:39pm |
Yes did all that would not eject but read on here that engine needed to be running tried that and worked ok , thanks for the reply. |
Fri Jun 20 2014 9:04pm |
If you now have the new one in, and it has updated, you will need to reset the country from the default Belgium or postcodes wont work. |
Fri Jun 20 2014 9:17pm |
Done that all appears to be okay, thanks. |
Sat Jun 21 2014 6:06pm |
