Home > In Car Electronics > Sat Nav Get's Lost
Paulg
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Sat Nav Get's Lost
I have a 2005 RRS HSE and my sat nav keeps thinking I am over water as its all blue. All other functions work fine and it works OK very so often. I have tried buying a new disk and upgrading but it still some times thinks I am over water.
Has anyone had this problem, any advise would be gratefully received apart from changing the car for a boat!
Post #426694 Mon Jun 09 2014 6:35pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
sounds like the gps needs recalibrating. ? 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #426707 Mon Jun 09 2014 9:02pm
BKHK
It sounds to me like it either needs a reset or the antenna or antenna signal is bad. I had similar before and it required a new antenna. Try the full reset first, I am not sure how you do that though. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #426712 Mon Jun 09 2014 9:32pm
Paulg
Smile
Thank you I will try that and see, will feedback on if it works
Post #426758 Tue Jun 10 2014 6:02pm
Paulg
OK have calibrated the Sat Nav and it within a few miles is lost again so it seems to be an aerial issue, does anyone have a link to a video of how to remove the aerial?
Post #426889 Wed Jun 11 2014 8:09pm
flack
You have to drop the roof lining at the rear, remove the two rear corner covers this allows you to drop the lining enough to get to the aerial, there is also a mounting point in the middle of the roof lining that just pulls out.
http://www.rrsport.co.uk/forum/topic32826.html
Flack Thumbs Up
Post #426934 Thu Jun 12 2014 8:29am
Paulg
This is great a big thank you.
I have placed my order and look forward to sorting this, will post how I get on
Post #426936 Thu Jun 12 2014 8:40am
