Home > In Car Electronics > Sat Nav Get's Lost |
Paulg Member Since: 07 Jun 2014 Location: Hornchurch Posts: 10 |
Mon Jun 09 2014 6:35pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
It sounds to me like it either needs a reset or the antenna or antenna signal is bad. I had similar before and it required a new antenna. Try the full reset first, I am not sure how you do that though. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Mon Jun 09 2014 9:32pm |
Tue Jun 10 2014 6:02pm |
OK have calibrated the Sat Nav and it within a few miles is lost again so it seems to be an aerial issue, does anyone have a link to a video of how to remove the aerial?
Wed Jun 11 2014 8:09pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You have to drop the roof lining at the rear, remove the two rear corner covers this allows you to drop the lining enough to get to the aerial, there is also a mounting point in the middle of the roof lining that just pulls out.
Thu Jun 12 2014 8:29am |
This is great a big thank you.
Thu Jun 12 2014 8:40am |
