Home > Technical > Oil leak and vibration |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Continental tyres do show wear at the shoulder because of the way the tread is designed. If the tyres aren't Continentals then I'd be asking why they think they're designed to wear that way.
Sun May 25 2014 6:15pm |
WillP Member Since: 15 Apr 2014 Location: Essex Posts: 57 |
They are continentals, so that seems to be correct then
Sun May 25 2014 6:28pm |
Hi there, the oil is dripping in a couple of places.
Mon May 26 2014 5:15pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
I can't really help much but I would make sure that they check the diffs. A bad rear diff can give you vibes at 60-70mph as can a front one with a problem. It doesn't sound from your description as if the oil and vibes are related but if they are then maybe be drive train and not engine related.
Mon May 26 2014 9:40pm |
