Home > Maintenance & Modifications > Land Rover say to not do the transmission oil replacement... |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
I recall from reading here that ZF (?) the manufacturer of the gearboxes said change the oil.
Tue May 20 2014 11:36pm |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
do it or you will have problems ,the oil inside your box has done a lot of miles and will need replacing silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed May 21 2014 5:27am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Gearbox oil starts to degrade at around 60k miles, so always worthwhile having it done before any irrepairable damage occurs |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
I keep finding that LR dealers resist doing non-standard work. I've come to the conclusion that they only want to do quick high profit stuff like services. Stuff that takes up a ramp for a few hours is resisted. 2012 SDV6 - it's missing a couple of cylinders
Wed May 21 2014 7:20am |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
anyone here able to carry out this gearbox flush in the Cardiff area ? RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Wed May 21 2014 8:36am |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
Thanks guys, I've it booked for the gearbox too now, they said they never do it, but I insisted I get it done, so they roll eyes and will do my request.
Wed May 21 2014 10:52pm |
Standard LR gearbox oil change is: empty some out, add some, drive it a bit, empty some out, top it back up to level. Result is that a good proportion of the old oil remains in the gearbox.
Wed May 21 2014 11:12pm |
I can almost believe them - the oil change is at ten years (I think). Most vehicles of that age will not be getting serviced by a main dealer. Similarly, I mentioned to my local LR dealer about the possibility of changing the dampers. "Hardly ever need to" was the reply. But as most older vehicles won't be serviced by them it's no surprise they never need to change the dampers - that sort of work will be done by a local general garage or an indie LR specialist somewhere. I've been tempted to change the spring/damper units myself but I fear the bolts will be a git to undo and also my torque wrench doesn't have a high enough setting for the bottom bolt. Could buy a new wrench I suppose... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed May 21 2014 11:18pm |
I'm glad I did push to get it done, but I've no idea on the cost - anyone know the sort of money extra to do it? I'd seen on ebay kits around £250 but I'm guessing LR will be a lot more. |
Wed May 21 2014 11:36pm |
Bear in mind that LR call their process something like "double flush" but it's not actually a flush at all.
Thu May 22 2014 6:30am |
A drain and refill replaces less than 4 litres of oil, in a gearbox that holds 11 litres. This replaces less than a third of the old oil. But, the new oil is contaminated straight away as it mixes with the existing old oil. A "double flush" is essentially a drain and refill twice. It is generally believed that a double flush replaces around 50% of the old oil. A Megaflush/Powerflush, whatever you want to call it, is essentially a dialysis machine for your gearbox. It is a machine connected into the cooler pipework, and uses the gearbox oil pump to push the old oil out, the machine measures the quantity of oil, and automatically replaces it with new oil The new oil and old oil are kept completely separate from each other
And by 10 years/150k miles old, all cars will be out of Manufacturers Warranty, and any gearbox issues will not be Land Rovers problem. ZF, the gearbox manufacturer, specify the oil should be changed every 75k miles. More often if doing a lot of off-roading or towing |
Thu May 22 2014 6:37am |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 |
any idea's who does this in kent as mines on 155K and has a little judder now and again ? |
Thu May 22 2014 6:18pm |
I was quoted £500 about 3 years ago by my dealer I would go full engine flush if it was me. |
Thu May 22 2014 6:30pm |
How would that help the gearbox?
Geoff. is your man. Not very active here, but is on the D3 forum |
Thu May 22 2014 8:57pm |
