Home > Maintenance & Modifications > Land Rover say to not do the transmission oil replacement...
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I called LR today as my car is in on thursday to get a look over and an oil change (not a service - just changing it as I bought it from a dealer and I want assurances its good oil) - the guys said to not change the oil for the gear box, but I'd read to do it on any gearbox >100k.
So I'm asking you guys since you are enthusiasts and will know what's a waste of cash and what is not. I just want to not have a bad gear box in a years time and kick myself over a few quids worth of oil.
Post #424816 Tue May 20 2014 10:56pm
Stuart
I recall from reading here that ZF (?) the manufacturer of the gearboxes said change the oil.
I had mine power flushed by one of the chaps on here.
Post #424821 Tue May 20 2014 11:36pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
do it or you will have problems ,the oil inside your box has done a lot of miles and will need replacing Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #424827 Wed May 21 2014 5:27am
Disco_Mikey
Gearbox oil starts to degrade at around 60k miles, so always worthwhile having it done before any irrepairable damage occurs Thumbs Up
Post #424828 Wed May 21 2014 5:27am
I keep finding that LR dealers resist doing non-standard work. I've come to the conclusion that they only want to do quick high profit stuff like services. Stuff that takes up a ramp for a few hours is resisted. 2012 SDV6 - it's missing a couple of cylinders
Post #424837 Wed May 21 2014 7:20am
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
anyone here able to carry out this gearbox flush in the Cardiff area ?  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #424842 Wed May 21 2014 8:36am
designboy
Thanks guys, I've it booked for the gearbox too now, they said they never do it, but I insisted I get it done, so they roll eyes and will do my request. Rolling Eyes
So I'm now wondering what the difference is with a flush and a re-oil? Is a flush an extra solvent added then cleared before the new oil?
Post #424946 Wed May 21 2014 10:52pm
Standard LR gearbox oil change is: empty some out, add some, drive it a bit, empty some out, top it back up to level. Result is that a good proportion of the old oil remains in the gearbox.
A flush is a non-LR system that uses a pump (either externally or using the gearbox's own pump) to replace as close to 100% of the oil as one can do without a full strip down of the gearbox.
The argument for using the latter system is that adding new oil to old oil just ends up in new contaminated oil. It's better than no change but it's not as good as the full change achieved by the flush system.
That's my understanding, anyway Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #424951 Wed May 21 2014 11:12pm
I can almost believe them - the oil change is at ten years (I think). Most vehicles of that age will not be getting serviced by a main dealer.
Similarly, I mentioned to my local LR dealer about the possibility of changing the dampers. "Hardly ever need to" was the reply. But as most older vehicles won't be serviced by them it's no surprise they never need to change the dampers - that sort of work will be done by a local general garage or an indie LR specialist somewhere.
I've been tempted to change the spring/damper units myself but I fear the bolts will be a git to undo and also my torque wrench doesn't have a high enough setting for the bottom bolt. Could buy a new wrench I suppose... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #424952 Wed May 21 2014 11:18pm
designboy
I'm glad I did push to get it done, but I've no idea on the cost - anyone know the sort of money extra to do it? I'd seen on ebay kits around £250 but I'm guessing LR will be a lot more.
Post #424953 Wed May 21 2014 11:36pm
Bear in mind that LR call their process something like "double flush" but it's not actually a flush at all.
As for cost, no idea. I would guess you're looking at £400+ from a dealer - oil, filter and labour assuming they do the full work rather than just change a bit of the oil. The filter change is a bit of a faff as it requires a subframe to be removed and the transmission/engine raised slightly to get the old filter out. I'm sure others can give a full description of the required work.
If you have a decent LR indie close by, I think you'd be better to get them to do it (cheaper labour) and also get them to do the "BMW mod". This replaces the plastic "all in one" filter tray at the bottom of the gearbox with a metal tray. The metal tray has a separate filter. This is what BMW have on their version of the same gearbox apparently, and allows the filter to be changed more easily. I think it requires different length bolts but, again, others will know more detail.
I haven't had the BMW-mod done as I have a LR warranty and I reckon they'd use it as an excuse to void any transmission claim. If you don't have a warranty then it's something to think about. 2012 SDV6 - it's missing a couple of cylinders
Post #424956 Thu May 22 2014 6:30am
Disco_Mikey
A drain and refill replaces less than 4 litres of oil, in a gearbox that holds 11 litres. This replaces less than a third of the old oil. But, the new oil is contaminated straight away as it mixes with the existing old oil.
A "double flush" is essentially a drain and refill twice. It is generally believed that a double flush replaces around 50% of the old oil.
A Megaflush/Powerflush, whatever you want to call it, is essentially a dialysis machine for your gearbox. It is a machine connected into the cooler pipework, and uses the gearbox oil pump to push the old oil out, the machine measures the quantity of oil, and automatically replaces it with new oil
The new oil and old oil are kept completely separate from each other
And by 10 years/150k miles old, all cars will be out of Manufacturers Warranty, and any gearbox issues will not be Land Rovers problem.
ZF, the gearbox manufacturer, specify the oil should be changed every 75k miles. More often if doing a lot of off-roading or towing
Post #424958 Thu May 22 2014 6:37am
Cupra
any idea's who does this in kent as mines on 155K and has a little judder now and again ?
Post #425043 Thu May 22 2014 6:18pm
I was quoted £500 about 3 years ago by my dealer Shocked I would go full engine flush if it was me. Wink
Post #425045 Thu May 22 2014 6:30pm
Disco_Mikey
How would that help the gearbox? Whistle
Geoff. is your man. Not very active here, but is on the D3 forum Thumbs Up
Post #425063 Thu May 22 2014 8:57pm
