Home > Wheels & Tyres > 22 inch tyre pressure? |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
The man is a nutter, only space savers run yhat high 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Sat Mar 30 2013 11:34pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Far from being a sceptic, but the guy has a vested interest at you wearing tyres out quicker 50 is way too high and it will take the centre out rapidly as wide tyres grow at speed to oval profile. Add 10 psi too much and they won't last 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Mar 31 2013 11:20am |
I once heard of a chalk technique to check the correct tyre pressures...something like you put a like of chalk on the tyre and drive so far and you see where its rubbed off.
Sun Mar 31 2013 5:04pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
thanks, handy 07 TDV8 + BAS map |
Mon Apr 01 2013 5:23pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
The 20's I've on have on the tyre wall max 50psi, I went to 43 on each off them but after reading this think I'll drop it back down, they are Pirelli Scorpion Zero - I thought 50 was a bit much! But now reading this think 43 is still a lot, might tail it back to 38 and less on the back. Anyone have these and what do you run them at?
Wed May 14 2014 1:03am |
Howler Member Since: 07 May 2014 Location: I'm in the Castle. Posts: 29 |
I have 20's on mine, and have the tyre pressures according to the book page 298 and the yellow stick it thingy just inside the front cover and they both say 34'F & 36R for normal load and 38F & 42R full load. Temp spare wheel all operating conditions set to 60.
Wed May 14 2014 9:05am |
The tyre pressure is on the door, use that.
Wed May 14 2014 9:20pm |
Yea I had a full car of guys today in it felt horrible to drive. I was in a suit or I'd have got out to fix it
Thu May 15 2014 12:44am |
There are two or three load set up tyre pressures like most cars
Thu May 15 2014 2:01pm |
RR-moggle Member Since: 16 Aug 2014 Location: Leeds Posts: 8 |
I have 22 inch overfinch - run at 40psi all round
Sun Aug 17 2014 8:18pm |
