![]() | Home > Wheels & Tyres > 22 inch tyre pressure? |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
The man is a nutter, only space savers run yhat high |
Far from being a sceptic, but the guy has a vested interest at you wearing tyres out quicker |
I once heard of a chalk technique to check the correct tyre pressures...something like you put a like of chalk on the tyre and drive so far and you see where its rubbed off.
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
thanks, handy 07 TDV8 + BAS map |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
The 20's I've on have on the tyre wall max 50psi, I went to 43 on each off them but after reading this think I'll drop it back down, they are Pirelli Scorpion Zero - I thought 50 was a bit much! But now reading this think 43 is still a lot, might tail it back to 38 and less on the back. Anyone have these and what do you run them at?
Howler Member Since: 07 May 2014 Location: I'm in the Castle. Posts: 29 ![]() ![]() ![]() |
I have 20's on mine, and have the tyre pressures according to the book page 298 and the yellow stick it thingy just inside the front cover |
The tyre pressure is on the door, use that.
Yea I had a full car of guys today in it felt horrible to drive. I was in a suit or I'd have got out to fix it |
There are two or three load set up tyre pressures like most cars
RR-moggle Member Since: 16 Aug 2014 Location: Leeds Posts: 8 ![]() ![]() ![]() |
I have 22 inch overfinch - run at 40psi all round
