Home > Wheels & Tyres > 22 inch tyre pressure?
m6totdv8
50 psi ....holy crap Shocked Shocked Current : Overfinch TDV8
Gone : BMW M6 V10
Gone : BMW 535d
Gone : BMW X5 4.6
Gone : BMW M3
Gone : Merc E280
Post #379217 Sat Mar 30 2013 9:24pm
shakeapaw
The man is a nutter, only space savers run yhat high Shocked 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #379234 Sat Mar 30 2013 11:34pm
simple1
Far from being a sceptic, but the guy has a vested interest at you wearing tyres out quicker Whistle 50 is way too high and it will take the centre out rapidly as wide tyres grow at speed to oval profile. Add 10 psi too much and they won't last Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #379273 Sun Mar 31 2013 11:20am
mse
I once heard of a chalk technique to check the correct tyre pressures...something like you put a like of chalk on the tyre and drive so far and you see where its rubbed off.
As i couldnt remember the technique i googled it: http://www.automedia.com/Optimizing_Tire_Pressure/ccr20010801tp/1 i did it once on a defender with different size muds on an it worked, maybe worth trying it Mike
2014 Facelift Discovery
Post #379296 Sun Mar 31 2013 5:04pm
jack.bauer
thanks, handy 07 TDV8 + BAS map
Post #379363 Mon Apr 01 2013 5:23pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
The 20's I've on have on the tyre wall max 50psi, I went to 43 on each off them but after reading this think I'll drop it back down, they are Pirelli Scorpion Zero - I thought 50 was a bit much! But now reading this think 43 is still a lot, might tail it back to 38 and less on the back. Anyone have these and what do you run them at?
It is more psi on the front due to the engine being there right? Idea
Post #424235 Wed May 14 2014 1:03am
Howler
England 2005 Range Rover Sport Supercharged Buckingham Blue
I have 20's on mine, and have the tyre pressures according to the book page 298 and the yellow stick it thingy just inside the front cover Rolling Eyes and they both say 34'F & 36R for normal load and 38F & 42R full load. Temp spare wheel all operating conditions set to 60.
Regards
Howler
Post #424246 Wed May 14 2014 9:05am
mse
The tyre pressure is on the door, use that.
The tyre pressure on the side wall is the max pressure before you will blow the tyre pressure out Mike
Post #424326 Wed May 14 2014 9:20pm
designboy
Yea I had a full car of guys today in it felt horrible to drive. I was in a suit or I'd have got out to fix it Sad
Back to the door card settings.
Post #424337 Thu May 15 2014 12:44am
mse
There are two or three load set up tyre pressures like most cars
usually 2+ baggage and 5+baggage... all on the door Mike
Post #424398 Thu May 15 2014 2:01pm
RR-moggle
I have 22 inch overfinch - run at 40psi all round
Thanks
Post #433538 Sun Aug 17 2014 8:18pm
