Home > General > (FIXED) The dreaded amber Light Thought to be suspension |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
I have replaced a couple of ecu's for the air system on D3's including my own and the second hand ecu's where from RRS's . I have only had to recalibrate two of them as some ecu's seem less tolerant to how far out the reading's are for the four corners.
Sun May 11 2014 2:04pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
The Bluetooth IIDTool gets my vote |
Sun May 11 2014 6:43pm |
PatGapInnov Member Since: 30 Jul 2012 Location: Montreal Posts: 42 |
Hi Guys
Tue May 13 2014 2:21pm |
daveyc Member Since: 09 May 2014 Location: Liverpool / Spain Posts: 56 |
Hi why would I need to flash the ecu with the latest firmware if the unit wasn't defective why would it show a fault now ? , also would the firmware flash be available to me or is this just a main dealer job , (go gentle im a noob to RRS) thx Dave 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Tue May 13 2014 3:38pm |
Hi Dave
The IIDTool and a few other diagnostic tools will allow you to re-flash or recalibrate the suspension ECU. Also there are guys like Mike and Flack that can do it for you if you are close to them. If in the end it is confirmed that the ECU is defective, you will need to proceed with a calibration and re-flashing if the replacement ECU is new. If it is used, it may only need a sensor calibration if the correct firmware is already installed. Cheers http://www.gap-diagnostic.com/ |
Tue May 13 2014 4:43pm |
Hi problem for me is I live in Spain and not involved with any people out her in the RRS scene I hardly speak the lingo also don't want to take it to the stealers as everything in mañana here even the simply things in life so could get very long and expensive , so was going to tackle as much of it myself I have a good knowledge of electronics and computers so really hoping I may be able to gain the knowledge from forums and sound advice from fellow members just need my own IId tool I think so I can progress , and at the moment it doesn't seem to affecting anything except the warning light , im wondering if the car had never had use of the ride height adjustments before it only had 29,000 on a 2006 might have been a school run bus but when I got it I was checking different controls out and was using the access height so wondering if I have something stuck that had not been used before possible a sensor etc. .... any help from any member would be appreciated 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Tue May 13 2014 5:02pm |
Hi Dave
Tue May 13 2014 5:47pm |
Thank you very much yes will be buying IID tool at end of the month .. 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Wed May 14 2014 11:16am |
Hi folks right just got my ID tool so will get stuck in at the week end and put the results on here & hope fully get some answers thx Dave 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Thu Jun 05 2014 12:48pm |
Fri Jun 06 2014 2:34pm |
Ok so the IID Tool is here just read the faults tried to clear them but they are permanent here is the read out
Fri Jun 06 2014 4:30pm |
Email sent... http://www.gap-diagnostic.com/
Fri Jun 06 2014 4:41pm |
Ok I been told that these faults are nothing to do with the amber suspension light leaning when cornering faults so here is a full read out of all ecu's im lost now
Fri Jun 06 2014 4:59pm |
Update the fault which initially thought to be the suspension is actually the ARC module not the suspension .
Tue Jun 10 2014 4:19pm |
