![]() | Home > General > (FIXED) The dreaded amber Light Thought to be suspension |
I would look at suspension sensors. If you have centre screen look at the 4x4 monitor, it will flag up a faulty one 2x TDV6. SE and HSE. Both returned to sender with issues👀
daveyc Member Since: 09 May 2014 Location: Liverpool / Spain Posts: 56 ![]() ![]() ![]() |
Hi checked that first no faults on the fitted screen , fault code c1a0004 , Internal control module fault this is what the mobile mechanic has said , don't want to buy a module to find I have to go to stealers ? |
If you were able read the code, could it be cleared? 2x TDV6. SE and HSE. Both returned to sender with issues👀
He tried reset everything just shows backup the dash light takes about 2 secs so it doesn't look like it clears, as I said at first it would clear by restarting now its there constantly , he said fault is permanent
Sounds like command module as you feared if all four sensors are showing clear. Would still try and get an Indi to clear the fault rather than using a general fault reader. 2x TDV6. SE and HSE. Both returned to sender with issues👀
For £100 ish can get a module but not sure if it needs programming to work in my RRS ? |
I don't think they are vehicle specific but I'm sure a grown up will correct me. 2x TDV6. SE and HSE. Both returned to sender with issues👀
The only thing that I can think of is the individual height for the calibration of each wheel as that would worry me if it the stability was effected , must be someone on her he can confirm if its just a swop over ? |
Thinking logically it will be the sensors that supply the height not the module, as the arms are a fixed length. Once the system has been placed in low ride and high positions the module then keeps those dimensions. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Anybody else have any views on me just being able to swop the control unit over without having to get it programmed by the stealers ? 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Did the chap use a Land Rover specific diagnostic computer? A lot of the generic code readers will not read the codes from D3/D4/FFRR/RRS properly. |
No it wasn't a RR dealer diag but he did say it cost him about £3500 and he pays extra £500 a year for updates also called there tech and they agreed that it was module , but no further help from that just the code and returning communication error from the module .. 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9022 ![]() ![]() ![]() |
If the air suspension control module is replaced then the system will need to be calibrated (just as it does if you replace a ride height sensor).
Hi when you say a IIDTool any recommendations and cost thx 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
