Home > Technical > Led trailer lights |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
Hi Muddywheels, there is heaps of info on this on the Aulro forum in D3/D4/RRS sub section. You can either buy units called "pulsebuster" or fit some resistors in the trailer wiring circuit. Easy job apparently. The RRS is looking to see some resistance from the "normal" 21W globe which the computer then senses, and recognizes that a trailer is there. So with LED's, this resistance is not there. By adding the correct resistors this then provides the car with the correct resistance. Use the search on the Aulro re LED lights and you should find plenty. SWMBO owns this car I get to drive occasionally |
Mon Mar 10 2014 12:06am |
MartyRRS Member Since: 04 Dec 2013 Location: Adelaide Hills South Australia Posts: 25 |
you could try this: http://www.ledtowconnect.com/
Mon Mar 10 2014 2:03am |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 |
I would wait until you have the caravan. If the two outside brake lights are non-LED you will probably be OK as the car will sense the two normal bulbs and therefore have no issues. |
Mon Mar 10 2014 3:08am |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5636 |
Cheers guys
Mon Mar 10 2014 10:33am |
I think it's just that we tow things more regularly here, boats especially and a lot of boat trailers have been converted to LED's as they are sealed units. |
Mon Mar 10 2014 11:20am |
simon645 Member Since: 30 Jan 2014 Location: cumbria Posts: 126 |
muddy, my 2013 bessacarr has high level brake light and side markers led and work ok |
Mon Mar 10 2014 9:36pm |
Good to hear
Mon Mar 10 2014 11:07pm |
Madasmad Member Since: 01 Mar 2013 Location: Crewe Posts: 37 |
Same with my Lunar Delta Muddy - no issues! What doesn't kill you only makes you stronger!
Wed Mar 12 2014 11:12am |
AndyLandy Member Since: 26 Nov 2013 Location: Bassingbourn Posts: 39 |
Hi everyone,
Sun May 11 2014 5:17pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
my brothers has led indicators and they flash constanly like hazard lights |
Sun May 11 2014 8:48pm |
