Home > Technical > Led trailer lights
muddywheels
Milk Float Man
Led trailer lights
I have ordered a new caravan and just realised it has high level centre led brake light but not sure about rest Shocked
I know lr advise tow electric not compatible for led lights even though it is becoming the norm and wondered if anyone has tried connecting to led yet - did it work or have you had to fix it Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #417163 Sun Mar 09 2014 9:43pm
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Hi Muddywheels, there is heaps of info on this on the Aulro forum in D3/D4/RRS sub section. You can either buy units called "pulsebuster" or fit some resistors in the trailer wiring circuit. Easy job apparently. The RRS is looking to see some resistance from the "normal" 21W globe which the computer then senses, and recognizes that a trailer is there. So with LED's, this resistance is not there. By adding the correct resistors this then provides the car with the correct resistance. Use the search on the Aulro re LED lights and you should find plenty. SWMBO owns this car I get to drive occasionally Smile
Post #417167 Sun Mar 09 2014 11:06pm
MartyRRS
Australia 2008 Range Rover Sport TDV8 SE Alaska White
you could try this: http://www.ledtowconnect.com/
this is the one I have: http://www.linearelectronicdesign.com/ Regards, Marty
Now: 2008 RRS TDV8; 1975 Rangie ute
Then: 2010 Defender Puma TdCi 110; 1996 Defender 300Tdi; 1997 Disco V8 on vsi gas; 1976 Rangie 4.4l; 20 yrs of back breaking Tojos
Post #417168 Mon Mar 10 2014 1:03am
idrabble
Australia
Re: Led trailer lights
I would wait until you have the caravan. If the two outside brake lights are non-LED you will probably be OK as the car will sense the two normal bulbs and therefore have no issues.
Post #417169 Mon Mar 10 2014 2:08am
muddywheels
Milk Float Man
Cheers guys Bow down
I have seen the disco threads before and it seems to be oz members posting with the issue so wondered if yours are different Confused
Hopefully if just middle brake light led it will be fine - guess I will have to wait and see Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #417176 Mon Mar 10 2014 9:33am
idrabble
Australia
I think it's just that we tow things more regularly here, boats especially and a lot of boat trailers have been converted to LED's as they are sealed units.
Post #417179 Mon Mar 10 2014 10:20am
simon645
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
muddy, my 2013 bessacarr has high level brake light and side markers led and work ok
Post #417247 Mon Mar 10 2014 8:36pm
muddywheels
Milk Float Man
Good to hear Very Happy
I'm expecting delivery in May and was worried as will be long way from home and not happy to tow with faulty lights Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #417266 Mon Mar 10 2014 10:07pm
Madasmad
Same with my Lunar Delta Muddy - no issues! What doesn't kill you only makes you stronger!
2008 RRS TDV8 330Bhp 800nm
Post #417430 Wed Mar 12 2014 10:12am
AndyLandy
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi everyone,
Just picked up a new Bailey Cartagena and the LED side markers front side lights and hi-level brakelight caused no issues with our 2008 2.7 sport. Very Happy
I did e mail Bailey customer services and the answer was , well if the LED lights do flicker drive with the side lights on Rolling with laughter Rules are for the obediance of fools and the guidence of wise men
Post #423958 Sun May 11 2014 4:17pm
shadrack
my brothers has led indicators and they flash constanly like hazard lights
Post #423987 Sun May 11 2014 7:48pm
