Home > General (L494) > Multi Height Towbar - detachable !!
les2802
Hi , I am new to this forum. Having had 2 older RRS I have recently taken delivery of a 14 plate HSE.
I ordered it with the multi height tow bar, as at the time of ordering could not justify the cost of an electric one. ( they have since halved in price ). To my horror it arrived and the tow bar is detachable , not bad you would think, but there is no lock. All that holds it to the car is a pin. This means you can remove the tow bar and anything attached to it in less than 10 seconds. perfect for thieves.
Has any one else got the multi height tow bar - did they know it was detachable - are they complaining about it. ?
Have written to Land Rover and they are hiding behind ' conversations held at time of purchase !!
Post #422379 Sat Apr 26 2014 11:46am
rangiejools
Australia
If its that easy to detach just take it off when you're not using it. RRS P460e
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #422441 Sat Apr 26 2014 10:59pm
les2802
HI, When not I use I do detach it - the problem is when you have something on it like a bike rack or trailer. Once parked up it is so easy to steal the item attached to it. This is the part I am finding frustrating.
Post #422451 Sun Apr 27 2014 7:01am
rangiejools
Australia
Good point! RRS P460e
Post #422464 Sun Apr 27 2014 8:39am
muddywheels
Milk Float Man
That is ridiculous Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #422478 Sun Apr 27 2014 9:52am
MAW
Unbelievable....
Can you post a picture for ideas (on security not taking it) Exclamation
Post #422579 Mon Apr 28 2014 10:05am
les2802
Hi Photo as taken at about the same angle as the Land Rover brochure. You will notice the silver 'ring'. this is the pull tab for the 'lock' . Pull this and then pull the big locating pin from the other side.
Using two hands I am now down to less than 5 seconds !!
Post #422596 Mon Apr 28 2014 1:09pm
MAW
Looks like LR are keeping all accessories like lights, spare wheels, grills and now tow bars readily removable.....
How can any engineer or designer think any of this is a good idea, have they recruited someone in from Lego.....
Post #422623 Mon Apr 28 2014 6:54pm
That definitely is a design 'FAIL' Shocked ON THE WAY: BMW F21 M140i
Post #422629 Mon Apr 28 2014 7:18pm
DavidHirst
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Somebody please tell me that piece of steel plate and £10.00 tow ball isn't a L/R genuine part Exclamation MY 09TDV8
Post #422639 Mon Apr 28 2014 8:04pm
The tow ball isn't the only part though. There is a sub frame that has to be added behind the bumper surround.
For a "practical" 4x4, it really is ridiculous that you have to add a whole new sub frame in order just to add a tow ball. I guess it's just another example of LR realising that its core market is "school run / city" 4x4 rather than "practical" 4x4 - they know that most won't tow so they can save weight and improve economy for the EU (and other) official figures.
It does make me wonder what the Defender replacement will be like... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #422663 Mon Apr 28 2014 10:05pm
DavidHirst
Go on got to ask. Including sub-frame, How much Question MY 09TDV8
Post #422677 Tue Apr 29 2014 5:52am
les2802
Ordered with car back in September - £705.00 !! including fitting.
Post #422690 Tue Apr 29 2014 7:29am
Renaco
Cange the quick release clip and use a small padlock.
Post #422693 Tue Apr 29 2014 7:33am
les2802
forgot to add Plus extra cost for the towing electrics to be fitted.
and yes this is the genuine Land Rover item !
Post #422694 Tue Apr 29 2014 7:34am
