![]() | Home > General (L494) > Multi Height Towbar - detachable !! |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 ![]() ![]() |
If its that easy to detach just take it off when you're not using it. RRS P460e
les2802 Member Since: 26 Apr 2014 Location: surrey Posts: 10 ![]() ![]() |
HI, When not I use I do detach it - the problem is when you have something on it like a bike rack or trailer. Once parked up it is so easy to steal the item attached to it. This is the part I am finding frustrating. |
Good point! RRS P460e
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
That is ridiculous |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Unbelievable....
Hi Photo as taken at about the same angle as the Land Rover brochure. You will notice the silver 'ring'. this is the pull tab for the 'lock' . Pull this and then pull the big locating pin from the other side.
Looks like LR are keeping all accessories like lights, spare wheels, grills and now tow bars readily removable.....
That definitely is a design 'FAIL' |
DavidHirst Member Since: 07 Sep 2013 Location: york Posts: 93 ![]() ![]() ![]() |
Somebody please tell me that piece of steel plate and £10.00 tow ball isn't a L/R genuine part |
The tow ball isn't the only part though. There is a sub frame that has to be added behind the bumper surround.
Go on got to ask. Including sub-frame, How much |
Ordered with car back in September - £705.00 !! including fitting. |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 ![]() ![]() |
Cange the quick release clip and use a small padlock. |
forgot to add Plus extra cost for the towing electrics to be fitted.
