![]() | Home > Technical > Dipped beam too low. |
It will need to be checked / adjusted at a garage on a beam setter ( any MOT testing station has one) there are no height adjusters on the dash like on other cars because the car has air sus so will always ride at the same height .. 2008 G4 RRSport TDV8 current
Leasky Member Since: 27 Feb 2014 Location: Aberdeen, Scotland. Posts: 35 ![]() ![]() ![]() |
Thanks very much for that, can I ask if it's a big job ie is there simply a manual adjustment which can be performed on the lights or does it involve removing items and some proper tinkering?
No take about 5/10 minutes straight forward on RRS 2008 G4 RRSport TDV8 current
Might be worth getting your ride height checked first. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
I believe there are 2 adjusters on each headlight, one for up / down and the other for left / right.
As Martyn says, it's a simple job to do using the adjusters on the units. Of course, if you do it yourself it's best to go out to a quiet, flat, straight bit of road and adjust them. Otherwise a 5 minute job for any decent garage.
dover Member Since: 22 Dec 2013 Location: Waipu Northland NZ Posts: 15 ![]() ![]() ![]() |
My lights on low beam are I think too high because a number on coming vehicles flash their lights at me, what is headlight dance business and how do you test it ? 2012 RRS. Orkney Grey |
