![]() | Home > Technical > Suspension |
The corner valves can get clogged with |
Yes, the strut is an air spring with a separate damper unit inside. 2012 SDV6 - it's missing a couple of cylinders
MGLEDHILL Member Since: 07 Aug 2010 Location: scotland Posts: 4 ![]() ![]() |
Thanks guys,
Sounds like you need to have your fault codes read, as a starting point |
