Home > Technical > Suspension |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4418 |
The corner valves can get clogged with passing through the system, giving air leaks due to the valves not sealing correctly.
Wed Apr 02 2014 7:52pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
Yes, the strut is an air spring with a separate damper unit inside. 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 02 2014 8:48pm |
MGLEDHILL Member Since: 07 Aug 2010 Location: scotland Posts: 4 |
Thanks guys,
Mon Apr 07 2014 1:51pm |
Sounds like you need to have your fault codes read, as a starting point |
Mon Apr 07 2014 5:19pm |
