Home > General > Rear passenger door won't open ?!?
jitzz
Hi All,
Need your collective expertise again ?!?....I've today got a problem with the offside rear passenger door which won't unlock with the remote key fob - all the other doors work fine. (It's a 2005 S/C by the way)
I press the remote and all the doors unlock except this one. To add to the problem, I have the child lock function activated, (as my 5 year old has this seat reserved) so can't open the door from the inside either Shocked
I think the problem started a week ago when I had to press the unlock on the key fob a few times to get it to open but now it's given up the ghost for good Big Cry
Has anyone else had this problem or know of a solution to fix - is it the lock mechanism itself ???
Any help or guidance would be very much appreciated
Thanks
Jitzz
Post #417446 Wed Mar 12 2014 2:30pm
dukeminster
I get this as well, but only intermittently. So would love to know if there is a fix.
Post #417449 Wed Mar 12 2014 3:19pm
Peanut
I also have this - there are several threads on here about changing the lock motor. But the motor is not cheap and it involves displacing the window glass which whilst I'm fairly confident, having seen one of the clips broken I'm not very happy with the idea!
For now get over it by using the unlock switch on the panel and at the same time gently...?.. pulling the black lever on the door... At present SWMBO has been told not to use the door......
Post #417452 Wed Mar 12 2014 3:26pm
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
I had very similar problem with mine. I found if you hold the latch in the unlock position while pressing the unlock button on the center console this will unlock it same as suggested by peanut. But ultimately it was only resolved by replacing the locking mechanism. The frequency of it not unlocking does increase with time before final failure in my experience Big Cry
Post #417456 Wed Mar 12 2014 4:05pm
jitzz
Brilliant thanks for the suggestions all...I'll try this tonight when I get home.
Will I have an issue opeing from the inside as the childlock function is on ??
Thanks
Jitzz
Post #417463 Wed Mar 12 2014 5:38pm
Saeedasghar
Yes I assume you will mate as its disabled via the child lock. I would unlock it as above and just use the put side handle to open the door itself. The opening and closing of the door shouldn't be effected just the locking process or unlocking will be I would think.
Post #417466 Wed Mar 12 2014 6:13pm
jitzz
Great news managed to get the door open at the weekend !!
Ordered a new locking mechanism whioch should be here tomorrow so will tackle the replacement later this week.
Any tips on removing the door panel would be greatly appreciated though Razz
it was a good excuse to buy a trim panel tool..I do like the little gadgets that make life easier Thumbs Up
Thanks again for the help everyone
Jitzz
Post #418084 Mon Mar 17 2014 5:39pm
Peanut
Jitz,
The trick is to look in the Disco 3 forum.
http://www.disco3.co.uk/forum/topic33743.html?highlight=
Let us know how you get on and where your source the motor from - I have the same job to do!
Post #418163 Tue Mar 18 2014 7:27am
simple1
Even with your new toy, order half a dozen trim clips anyway as they always break and be careful with the connection to the outer handle or you will be ordering one of those too Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #418168 Tue Mar 18 2014 8:45am
Disco_Mikey
http://www.disco3.co.uk/forum/topic101872.html
Post #418170 Tue Mar 18 2014 8:52am
jitzz
Brilliant thanks for the linkey fellas spot on !! Very Happy
with regards to the latch mechanism, I got it from Sturgess L/R in Leicester the cost was �89 + VAT, thought it was a bit expensive but everywhere else was similar.
The one thing the guy did say that if I had a L/R warranty it would have been covered and fitted FOC Crying or Very sad
He also gave me a frightener by saying if you can't open it ...it's a new door, cos they need to prise the door skin back to get at the mechanism....apparently, they did one not long ago, needless to say I nearly soiled my trousers at this point.
I'll let you know progress later this week when I get onto it
Thanks again
Jitzz
Post #418240 Tue Mar 18 2014 2:15pm
OvalAutos
Nice one Peanut Bow down
We've got an L494 in at the moment and the NSR door wouldn't open. Thought we might have to destroy the door card, but your trick worked with a slight modification. It was a 2 man job; one sat in the back and holding both the inner & outer handles in the open position, then activate the lock/unlock switch on the driver's door. Release the handles and then use the outer handle (child lock was on) to open the door. Thumbs Up Joe
Post #609905 Fri Feb 12 2021 3:39pm
Ash3
Evening All
Resurrecting an old thread.
My offside rear door wont open.
When pressing the lock/ unlock button on the key fob I can hear the lock engage/disengage but it just won't open. Or at least it sounds lime it does.
Child lock has not been operated.
Any ideas/advice would be greatly appreciated Thumbs Up
Post #615067 Tue Jun 22 2021 10:46pm
Farmer Chalk
It’s a replacement lock time…incredibly common on all Freelanders, Discovery’s and RRS’s
There are tiny motors (size of scalextrix) which eventually wear out… whole lock mechanism needs changing…parts are £50ish for a pattern lock or about £100 for a genuine one…
Reasonable easy but very fiddly to do…. I have now done three on our Freelanders and one on our D3…
Look on You tube for how to do it!
Post #615095 Wed Jun 23 2021 7:46pm
Ash3
Cheers Farmer Chalk.
Could it be the deadlock ( I always oprate deadlock) or cable, ro resistance on pulling handle.
Is it individual motors in each I door I assume?
Post #615096 Wed Jun 23 2021 7:55pm
