![]() | Home > General > Rear passenger door won't open ?!? |
dukeminster Member Since: 26 Apr 2013 Location: United Kingdom Posts: 29 ![]() ![]() ![]() |
I get this as well, but only intermittently. So would love to know if there is a fix. |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
I also have this - there are several threads on here about changing the lock motor. But the motor is not cheap and it involves displacing the window glass which whilst I'm fairly confident, having seen one of the clips broken I'm not very happy with the idea!
Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
I had very similar problem with mine. I found if you hold the latch in the unlock position while pressing the unlock button on the center console this will unlock it same as suggested by peanut. But ultimately it was only resolved by replacing the locking mechanism. The frequency of it not unlocking does increase with time before final failure in my experience |
jitzz Member Since: 10 Dec 2012 Location: Loughborough Posts: 26 ![]() ![]() ![]() |
Brilliant thanks for the suggestions all...I'll try this tonight when I get home.
Yes I assume you will mate as its disabled via the child lock. I would unlock it as above and just use the put side handle to open the door itself. The opening and closing of the door shouldn't be effected just the locking process or unlocking will be I would think. |
Great news managed to get the door open at the weekend !!
Jitz,
Even with your new toy, order half a dozen trim clips anyway as they always break and be careful with the connection to the outer handle or you will be ordering one of those too |
Brilliant thanks for the linkey fellas spot on !! |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Nice one Peanut ![]() We've got an L494 in at the moment and the NSR door wouldn't open. Thought we might have to destroy the door card, but your trick worked with a slight modification. It was a 2 man job; one sat in the back and holding both the inner & outer handles in the open position, then activate the lock/unlock switch on the driver's door. Release the handles and then use the outer handle (child lock was on) to open the door. ![]() |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Evening All
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
It’s a replacement lock time…incredibly common on all Freelanders, Discovery’s and RRS’s
Cheers Farmer Chalk.
