Home > General > Rear passenger door won't open ?!? |
dukeminster Member Since: 26 Apr 2013 Location: United Kingdom Posts: 29 |
I get this as well, but only intermittently. So would love to know if there is a fix. |
Wed Mar 12 2014 2:19pm |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 |
I also have this - there are several threads on here about changing the lock motor. But the motor is not cheap and it involves displacing the window glass which whilst I'm fairly confident, having seen one of the clips broken I'm not very happy with the idea!
Wed Mar 12 2014 2:26pm |
Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104 |
I had very similar problem with mine. I found if you hold the latch in the unlock position while pressing the unlock button on the center console this will unlock it same as suggested by peanut. But ultimately it was only resolved by replacing the locking mechanism. The frequency of it not unlocking does increase with time before final failure in my experience |
Wed Mar 12 2014 3:05pm |
jitzz Member Since: 10 Dec 2012 Location: Loughborough Posts: 26 |
Brilliant thanks for the suggestions all...I'll try this tonight when I get home.
Wed Mar 12 2014 4:38pm |
Yes I assume you will mate as its disabled via the child lock. I would unlock it as above and just use the put side handle to open the door itself. The opening and closing of the door shouldn't be effected just the locking process or unlocking will be I would think. |
Wed Mar 12 2014 5:13pm |
Great news managed to get the door open at the weekend !!
Mon Mar 17 2014 4:39pm |
Jitz,
Tue Mar 18 2014 6:27am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Even with your new toy, order half a dozen trim clips anyway as they always break and be careful with the connection to the outer handle or you will be ordering one of those too 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Mar 18 2014 7:45am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Tue Mar 18 2014 7:52am |
Brilliant thanks for the linkey fellas spot on !!
Tue Mar 18 2014 1:15pm |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 |
Nice one Peanut We've got an L494 in at the moment and the NSR door wouldn't open. Thought we might have to destroy the door card, but your trick worked with a slight modification. It was a 2 man job; one sat in the back and holding both the inner & outer handles in the open position, then activate the lock/unlock switch on the driver's door. Release the handles and then use the outer handle (child lock was on) to open the door. Joe |
Fri Feb 12 2021 2:39pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Evening All
Tue Jun 22 2021 9:46pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 |
It’s a replacement lock time…incredibly common on all Freelanders, Discovery’s and RRS’s
Wed Jun 23 2021 6:46pm |
Cheers Farmer Chalk.
Wed Jun 23 2021 6:55pm |
