Home > Technical > Bit of smoke near headlights UPDATE 6/5/2014
gizzmo
sounds like a blow back from the air filter box making its way into the front wing tunnel. your air filter box is probably not sitting firmly against the side wall
Post #417956 Sun Mar 16 2014 7:17pm
RRS Daz
What should I look for?
Post #417970 Sun Mar 16 2014 8:09pm
SPX
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I had this exact problem on my D3 TDV6, turned out to be an injector leaking on to the exhaust heat shield.
Post #417971 Sun Mar 16 2014 8:19pm
RRS Daz
That doesn't sound too good!
Would it be the same on the tdv8? Can I get to check them easy on the tdv8?
Post #417982 Sun Mar 16 2014 8:59pm
RRS Daz
Must be fbh as it's 8 deg now and got no smoke.
I'll have to keep and eye on it and reply with temps.
Post #418019 Mon Mar 17 2014 8:46am
RRS Daz
UPDATE!
Well it's definatly not the fbh.
Taken the cover of and found wet on the drivers side around what I think are the injectors!!
So hit the search button and Paul's thread come up but I have no running issues, another thread come up which stated it was an oring that had failed.
What shall I do next?
I started taking the metal guard off but it looks like half the crap on the chassis leg has to come off but I hope I could be the spill rail too...
Post #423397 Tue May 06 2014 5:03pm
RRS Daz
Just an update as I've found the problem.
It pouring out of the oring for the spill rail (that's what I think it's called) so should be a cheap fix but how much diesel must I have lost as it's been smoking for ages!!!
Also it's a right pain to get all the crap out to get to where you need to be.
Post #423425 Tue May 06 2014 8:51pm
