Home > Technical > Video of leak, can you tell where its from? |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
Sadly i think ive seen where its coming from, after jacking up the rear, second vid on its way
Fri Mar 07 2014 1:26pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
When mine leaked like that it required a full replacement...
Fri Mar 07 2014 2:58pm |
I think i was kidding myself |
Fri Mar 07 2014 3:16pm |
£1,620 OUCH...!!
Fri Mar 07 2014 4:01pm |
Sounds about right. It's £800-900 for the anti roll bar and then a lot of labour - it's a body off job I believe. 2012 SDV6 - it's missing a couple of cylinders
Fri Mar 07 2014 7:20pm |
There is two systems, early type is £750 ish and the later is £995, gues what one get to have? lol |
Fri Mar 07 2014 11:06pm |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 |
would it not be covered under a warranty |
Wed Mar 12 2014 7:07pm |
Floggitt Member Since: 04 Mar 2014 Location: llandysul Posts: 20 |
Take out a warranty and leave it a couple of weeks then "find" the problem? |
Tue Mar 18 2014 9:49pm |
Im far to honest to something like that, im going to get it done by Aylmers, he's rates are not bad. |
Tue Mar 18 2014 10:01pm |
The TDV8 has a slightly larger unit than that fitted to other models. That's probably why it's a bit pricier too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Mar 18 2014 11:13pm |
