Home > Technical > Video of leak, can you tell where its from?
Paul Holywood
hi all ive notice a oil stain of late on my drive, and thought i would reach under and video it for some advice on where it may be coming from.
many thanks
Post #416925 Fri Mar 07 2014 1:05pm
Paul Holywood
Sadly i think ive seen where its coming from, after jacking up the rear, second vid on its way Big Cry
clutching at straws here, but does the second pipe connector at the end of the vid look like it MAY and i say May in the hope of a cheap fix, be coming from the O-ring??
I can clearly see a drip around the O-ring connection on the inside pipe, and hope its the culprit
quick wipe and test drive.
Post #416928 Fri Mar 07 2014 1:26pm
When mine leaked like that it required a full replacement... Sad
Fingers crossed yours doesn't 2012 SDV6 - it's missing a couple of cylinders
Post #416935 Fri Mar 07 2014 2:58pm
Paul Holywood
I think i was kidding myself Crying or Very sad
Post #416938 Fri Mar 07 2014 3:16pm
Paul Holywood
£1,620 OUCH...!!
thats from Indi.
Post #416943 Fri Mar 07 2014 4:01pm
Sounds about right. It's £800-900 for the anti roll bar and then a lot of labour - it's a body off job I believe. 2012 SDV6 - it's missing a couple of cylinders
Post #416960 Fri Mar 07 2014 7:20pm
Paul Holywood
There is two systems, early type is £750 ish and the later is £995, gues what one get to have? lol
Post #416990 Fri Mar 07 2014 11:06pm
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
would it not be covered under a warranty Question Question Question
Post #417485 Wed Mar 12 2014 7:07pm
Floggitt
Wales 2009 Range Rover Sport TDV6 SE Santorini Black
Take out a warranty and leave it a couple of weeks then "find" the problem?
Post #418381 Tue Mar 18 2014 9:49pm
Paul Holywood
Im far to honest to something like that, im going to get it done by Aylmers, he's rates are not bad.
Post #418386 Tue Mar 18 2014 10:01pm
The TDV8 has a slightly larger unit than that fitted to other models. That's probably why it's a bit pricier too. 2012 SDV6 - it's missing a couple of cylinders
Post #418398 Tue Mar 18 2014 11:13pm
