![]() | Home > Technical > Battery ? |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Hi Chris, I disconnected my old cars (TDV8) battery to charge it overnight and had no problem at all when I re connected it so you should be ok MY16 AUTOBIOGRAPHY Indus silver with some toys
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
Thanks for that. I was worried that I might get fault codes coming up and radio lock code.
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Just one thing before you disconnect it, let the vehicle 'go to sleep', by that, I mean wait for the red park brake light on instrument cluster to go out first. |
Thanks for help |
I would take the key out, and close all doors etc,( except bonnet obviously), I know you may only be changing the battery, but all the time the key is in, doors open etc, and engine not running,the battery whilst connected, will be being drained by these. |
Haybale Member Since: 25 Jul 2013 Location: Co Durham Posts: 30 ![]() ![]() ![]() |
Which battery did you go for?
I went for the bosh S4013 £89 on eBay. All seems ok and there are a few members on here that have used it. So I thought if there are happy I will be. |
SimonR Member Since: 29 Sep 2013 Location: Horsham Posts: 25 ![]() ![]() ![]() |
I was having starting problems at the start of the winter as the weather got colder and replaced the OE battery which still tested good for a Varta the same size - it's made a huge difference. Cost about £100 from a local motor factor - and they delivered it to me within 30 mins! I've kept the old one and charged it - just in case it ever needs jump starting in the future! Si |
Good idea |
Nice one, cheers |
