Home > Technical > Battery ? |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Hi Chris, I disconnected my old cars (TDV8) battery to charge it overnight and had no problem at all when I re connected it so you should be ok MY16 AUTOBIOGRAPHY Indus silver with some toys
Sun Feb 23 2014 10:54pm |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 |
Thanks for that. I was worried that I might get fault codes coming up and radio lock code.
Sun Feb 23 2014 11:03pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
Just one thing before you disconnect it, let the vehicle 'go to sleep', by that, I mean wait for the red park brake light on instrument cluster to go out first. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Mon Feb 24 2014 12:10am |
Thanks for help
Mon Feb 24 2014 10:02am |
I would take the key out, and close all doors etc,( except bonnet obviously), I know you may only be changing the battery, but all the time the key is in, doors open etc, and engine not running,the battery whilst connected, will be being drained by these. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Mon Feb 24 2014 10:25am |
Haybale Member Since: 25 Jul 2013 Location: Co Durham Posts: 30 |
Which battery did you go for?
Mon Mar 03 2014 8:46pm |
I went for the bosh S4013 £89 on eBay. All seems ok and there are a few members on here that have used it. So I thought if there are happy I will be. |
Mon Mar 03 2014 11:14pm |
SimonR Member Since: 29 Sep 2013 Location: Horsham Posts: 25 |
I was having starting problems at the start of the winter as the weather got colder and replaced the OE battery which still tested good for a Varta the same size - it's made a huge difference. Cost about £100 from a local motor factor - and they delivered it to me within 30 mins! I've kept the old one and charged it - just in case it ever needs jump starting in the future! Si |
Tue Mar 04 2014 12:33pm |
Good idea |
Tue Mar 04 2014 4:07pm |
Nice one, cheers |
Tue Mar 04 2014 9:08pm |
