Home > General > Timed Climate & RPH |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
I have used my timed climate and it comes on but unless outside temp is very low (below about 5-7 deg) it just blows cold air
Tue Feb 11 2014 2:06pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Hi Bomber, did you make sure they activated the timed climate(obviously did as you have the icon) and the remote option, there are 2 things that have to be activated. 1 for screen and 1 for remote? MY16 AUTOBIOGRAPHY Indus silver with some toys
Tue Feb 11 2014 9:40pm |
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 |
Rigsby, what would the remote option be called within the cars on board system?
Tue Feb 11 2014 10:38pm |
Hi Bomber, do a search for a thread by rstebbings. The thread is called "timed climate - upgrade" and it has a picture of the settings on there. The feature that needs to be turned on within the timed climate screen is "call start" and this is the remote fob bit. Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Feb 12 2014 8:00am |
Thanks
Wed Feb 12 2014 9:13am |
Sounds like "call start" could be the equivalent. Worth giving it a try before you leave the indi MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Feb 12 2014 9:35am |
There are three options on the drop down usually when enabling.
Wed Feb 12 2014 4:08pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
muddywheels have you got remote park heating in your car now? Timed climate (already present in HSE Black) isn't of much use to me (irregular car usage pattern) but remotely firing it up on demand is much more practical.
Fri Feb 14 2014 10:50pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Fkarim - I'm sure mse has done it. If he sees this in sure he'll comment ON THE WAY: BMW F21 M140i
Fri Feb 14 2014 10:54pm |
Thanks BC. Will send him a PM when the parts arrive and my car comes back too |
Fri Feb 14 2014 11:19pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
You need to edit the CCF and the EUCD
Sat Feb 15 2014 12:17am |
Thanks aljo. Will enable these settings and great tip about letting the car go to sleep - didn't know that. |
Sat Feb 15 2014 8:20am |
Sorry just seen this fkarim
Sat Feb 15 2014 8:55am |
Unbeilievably easy to fit
Sat Feb 15 2014 9:01am |
