Home > Technical > Help please "Engine Fault Special Programmes not availa |
Has it only done short trip for a while? - check your battery voltage.
Tue Feb 11 2014 9:42am |
cisco1 Member Since: 14 Dec 2012 Location: Yorkshire Posts: 26 |
Hi drdelrrs
Tue Feb 11 2014 9:51am |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
Look here;
Tue Feb 11 2014 10:18am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
It needs the fault codes reading, you don't say which engine but would suspect EGR valves or turbo 2008 G4 RRSport TDV8 current
Sorry RRS 06 Size (CC): 2720 |
Tue Feb 11 2014 10:22am |
Still as I said above read the codes 2008 G4 RRSport TDV8 current
Tue Feb 11 2014 10:26am |
Just a quick update, had the friendly AA come out today.
Wed Feb 12 2014 6:41pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
It might be the Turbo actuator rod stuck that needs freeing off, it's a known fault. Have you also had your alternator checked out.?.
Wed Feb 12 2014 7:10pm |
Hi Flack
Wed Feb 12 2014 7:30pm |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
Hi mine did the same when map sensor failed. Everything went into limp mode. Garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed Feb 12 2014 8:19pm |
Hi gazzc
Wed Feb 12 2014 9:28pm |
Yes exactly but i swapped sensor off my other sport to save buying sensor and was fine silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed Feb 12 2014 11:37pm |
Quick update battery checked no probs Map Sensor taken off nicely cleaned and put back.
Thu Feb 13 2014 8:28pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
Mine did exactly the same as the OP's today (while giving it some wellie). I turned it off and on again and it was fine after. So something is on the way out.
Sat Aug 02 2014 3:27pm |
