![]() | Home > Technical > Help please "Engine Fault Special Programmes not availa |
Has it only done short trip for a while? - check your battery voltage.
cisco1 Member Since: 14 Dec 2012 Location: Yorkshire Posts: 26 ![]() ![]() ![]() |
Hi drdelrrs
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Look here;
It needs the fault codes reading, you don't say which engine but would suspect EGR valves or turbo 2008 G4 RRSport TDV8 current
Sorry RRS 06 Size (CC): 2720 |
Still as I said above read the codes 2008 G4 RRSport TDV8 current
Just a quick update, had the friendly AA come out today.
It might be the Turbo actuator rod stuck that needs freeing off, it's a known fault. Have you also had your alternator checked out.?.
Hi Flack
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Hi mine did the same when map sensor failed. Everything went into limp mode. Garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Hi gazzc
Yes exactly but i swapped sensor off my other sport to save buying sensor and was fine |
Quick update battery checked no probs Map Sensor taken off nicely cleaned and put back.
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine did exactly the same as the OP's today (while giving it some wellie). I turned it off and on again and it was fine after. So something is on the way out.
