Home > Technical > Help please "Engine Fault Special Programmes not availa
cisco1
Good Morning to All
First point of call always this forum, needed some help please.
O6 RRS Sport the wifey had problems last week driving it told me the Engine Fault message was showing, after a few attempts all was ok.
I did not think much to it until this morning, turned the key and POP message Engine Fault followed by "special programmes not available"
Everything works fine as the engine runs etc but no acceleration as if to say it is stuck in first gear, so had to reverse it up the street parked it up and came to work.
Worried what the issue is going to be but more importantly cost, could anyone please advise or help please could it be the battery ? Big Cry Big Cry Big Cry
Post #413438 Tue Feb 11 2014 9:06am
drdelrrs
Has it only done short trip for a while? - check your battery voltage.
Since it only takes a few minutes you could try the old favourite the 'hard reset'.
If that fails you may have stuck EGR.
Post #413443 Tue Feb 11 2014 9:42am
cisco1
Hi drdelrrs
Thank you for helping, 17 miles to wok and back and the odd run to the in-laws approx 41 miles.
I will get battery checked could you please advise on the 'hard reset' and how to do this please.
Post #413445 Tue Feb 11 2014 9:51am
Andi
Look here;
http://www.rrsport.co.uk/forum/topic32294....hard+reset
Post #413450 Tue Feb 11 2014 10:18am
Camelrock
It needs the fault codes reading, you don't say which engine but would suspect EGR valves or turbo 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #413451 Tue Feb 11 2014 10:18am
cisco1
Sorry RRS 06 Size (CC): 2720
Post #413453 Tue Feb 11 2014 10:22am
Camelrock
Still as I said above read the codes 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #413455 Tue Feb 11 2014 10:26am
cisco1
Just a quick update, had the friendly AA come out today.
Read codes no fault codes to report, trying to read his writing it says something on the lines of "remove and cleaned connections on throttle """"""""" and throttle body. Then a call saying its working fine.
The Mrs gets home and tries same message, i thought i would give it a go when i returned home tried first time no joy tried again no messages and everything all fine again.
Now im concerened whats going on any ideas ?? Big Cry Big Cry
Post #413716 Wed Feb 12 2014 6:41pm
flack
It might be the Turbo actuator rod stuck that needs freeing off, it's a known fault. Have you also had your alternator checked out.?.
Flack Thumbs Up
Post #413718 Wed Feb 12 2014 7:10pm
cisco1
Hi Flack
Thank you for this, what you suggested would this be the cause of "engine fault message" along with special programmes not available message ?
I will maybe have to get the AA out and get them to check the alternator.
Will advise
Thank you again for your time much appreciated
Post #413722 Wed Feb 12 2014 7:30pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Hi mine did the same when map sensor failed. Everything went into limp mode. Garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #413731 Wed Feb 12 2014 8:19pm
cisco1
Hi gazzc
Thanks for reading up, did yours show the same faults ??
What was the cost for fix ??
Thank you
Post #413744 Wed Feb 12 2014 9:28pm
gazzc
Yes exactly but i swapped sensor off my other sport to save buying sensor and was fine Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413777 Wed Feb 12 2014 11:37pm
cisco1
Quick update battery checked no probs Map Sensor taken off nicely cleaned and put back.
Alll sort of seem's ok now if problem continues i will purchase new Map Sensor then maybe try alternator.
Post #413912 Thu Feb 13 2014 8:28pm
Stuart
Mine did exactly the same as the OP's today (while giving it some wellie). I turned it off and on again and it was fine after. So something is on the way out.
What do we do with the turbo actuator rod, just dowse it in WD40? I may as well start there.
Post #432172 Sat Aug 02 2014 3:27pm
