Home > Technical > Changing wheel size
Tiny Timmy
Changing wheel size
Can someone tell me, when changing wheel size say 20" to 19" Is it just a case of swapping them over and letting the suspension sort it???
Post #411541 Tue Jan 28 2014 11:01pm
JimR
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
So long as the tyre size is correct the outside diameter will be the same and there will be nothing to sort out. ---------------------------
MY13 HSE Black Edition
Santorini Black with Black Interior
It's Very Black
Post #411543 Tue Jan 28 2014 11:14pm
Tiny Timmy
Great cheers Thumbs Up
Post #411549 Wed Jan 29 2014 6:19am
myfirstrrs
Could someone please tell me if that also applies to changing 22" to 20" wheels Confused on a 2007 TDV8 3.6? I have been reading that 22" heels can cause problems so thought the first thing I should do is to swap them. 20" might be a bit more comfy also.
Confused
Post #411551 Wed Jan 29 2014 6:28am
myfirstrrs
Make that wheels, I have no secrets, honest!
Post #411552 Wed Jan 29 2014 6:29am
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Rolling with laughter Stairs must be a real bastward for you mate. Rolling with laughter
Seriously though, I have 22's (wheels that is) myself and was wondering the same, if there is anything that needs to be done when dropping down to 20's or is it just a matter of changing them over. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #411558 Wed Jan 29 2014 8:53am
myfirstrrs
Thanks mad-dafty, fortunately I live in a bungalow.
There is a lot of expereince on this forum so I am hoping that someone can help us out with this info.
Post #411563 Wed Jan 29 2014 9:11am
HAWKE Styling
Hi guys, we produce and fit 22" wheels to RR marques, and there is no issue other than choosing the correct tyre size and keeping as close as poss to the correct rolling radius for the car.
With any car, the the bigger you go wheels wise, the harder the ride. With RR models however, the good suspension makes 22" still a comfy ride.
You will def need to avoid deep potholes with 22"s as the weight of the car coupled with lower tyre profile can cause any wheel to crack - regardless of how well made. In USA, they often fit 24"s to RR's which is a little extreme by our standards, but the roads are not ravaged by ice and snow and breaking up every year like ours!
To answer the question, bigger wheel means smaller tyre, but as the overall height is the same, the car is fine. The image below explains what we mean with a little help from Photoshop...
The red line is the overall height being the same for both wheels when fitted with correct tyre.
The white lines show the diff between the tyre ratio on an 18" compared to fitted with 22"
Hope this helps explain Thumbs Up
 Site sponsor and online seller of Range Rover Styling accessories and HAWKE Alloy wheels.
http://shop.sixonetwo.co.uk/range-rover-accessories
www.hawkestyling.com
Post #411577 Wed Jan 29 2014 10:09am
drdelrrs
Confused
Unless the person fitting the 22s also changed settings - which is very unlikely - you should be able to go back to the 20" wheels with no issues. Just check the tyre profile is in-line with the LR approved size.
Post #411578 Wed Jan 29 2014 10:13am
mad-dafty
Thanks for the info drdelrrs and hawke....
Much appreciated. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #411580 Wed Jan 29 2014 10:24am
drdelrrs
Hawke said "...In USA, they often fit 24"s to RR's which is a little extreme by our standards, but the roads are not ravaged by ice and snow and breaking up every year like ours! ..."
Based on the guys I know I'm not really convinced that "they often fit 24s..." apart from the few idiots with 'pimped rides' and chrome spinners Big Cry
Have you been to the States ? - their roads are pretty much like ours, and, as for the weather, you must be thinking of the southern states because most states from Kentucky north get plenty of snow each year.
Post #411588 Wed Jan 29 2014 11:52am
HAWKE Styling
Lol - Yes was thinking from experience of our visits to the sunny West Coast & Las Vegas Sema i guess.
Maybe I should have been more geographically specific.
We have a bespoke wheel maker in LA that has made one-off sets for us. We had a commission for a set of our wheels in 24" for a client - not to everyone's taste agreed Wink
Wasn't intending to generalise about the whole USA drdelrrs. I'm sure they get all sorts of weather! Site sponsor and online seller of Range Rover Styling accessories and HAWKE Alloy wheels.
Post #411597 Wed Jan 29 2014 12:23pm
Tiny Timmy
Thanks for your help Hawke makes it a bit clearer Thumbs Up You learn everyday Smile Thumbs Up
Post #411639 Wed Jan 29 2014 4:32pm
HAWKE Styling
Thumbs Up Site sponsor and online seller of Range Rover Styling accessories and HAWKE Alloy wheels.
Post #411644 Wed Jan 29 2014 4:50pm
