![]() | Home > Technical > Changing wheel size |
JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66 ![]() ![]() ![]() |
So long as the tyre size is correct the outside diameter will be the same and there will be nothing to sort out. ---------------------------
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Great cheers |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Could someone please tell me if that also applies to changing 22" to 20" wheels |
Make that wheels, I have no secrets, honest! |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
Thanks mad-dafty, fortunately I live in a bungalow.
HAWKE Styling Member Since: 05 Nov 2013 Location: Luton, Bedfordshire, LU3 3HP Posts: 59 ![]() ![]() |
Hi guys, we produce and fit 22" wheels to RR marques, and there is no issue other than choosing the correct tyre size and keeping as close as poss to the correct rolling radius for the car.
Unless the person fitting the 22s also changed settings - which is very unlikely - you should be able to go back to the 20" wheels with no issues. Just check the tyre profile is in-line with the LR approved size. |
Thanks for the info drdelrrs and hawke....
Hawke said "...In USA, they often fit 24"s to RR's which is a little extreme by our standards, but the roads are not ravaged by ice and snow and breaking up every year like ours! ..."
Lol - Yes was thinking from experience of our visits to the sunny West Coast & Las Vegas Sema i guess.
Thanks for your help Hawke makes it a bit clearer |
