Home > Technical > Changing wheel size |
JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66 |
So long as the tyre size is correct the outside diameter will be the same and there will be nothing to sort out. ---------------------------
Tue Jan 28 2014 11:14pm |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 |
Great cheers |
Wed Jan 29 2014 6:19am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Could someone please tell me if that also applies to changing 22" to 20" wheels on a 2007 TDV8 3.6? I have been reading that 22" heels can cause problems so thought the first thing I should do is to swap them. 20" might be a bit more comfy also.
Wed Jan 29 2014 6:28am |
Make that wheels, I have no secrets, honest! |
Wed Jan 29 2014 6:29am |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 |
Stairs must be a real bastward for you mate.
Wed Jan 29 2014 8:53am |
Thanks mad-dafty, fortunately I live in a bungalow.
Wed Jan 29 2014 9:11am |
HAWKE Styling Member Since: 05 Nov 2013 Location: Luton, Bedfordshire, LU3 3HP Posts: 59 |
Hi guys, we produce and fit 22" wheels to RR marques, and there is no issue other than choosing the correct tyre size and keeping as close as poss to the correct rolling radius for the car.
Wed Jan 29 2014 10:09am |
Unless the person fitting the 22s also changed settings - which is very unlikely - you should be able to go back to the 20" wheels with no issues. Just check the tyre profile is in-line with the LR approved size. |
Wed Jan 29 2014 10:13am |
Thanks for the info drdelrrs and hawke....
Wed Jan 29 2014 10:24am |
Hawke said "...In USA, they often fit 24"s to RR's which is a little extreme by our standards, but the roads are not ravaged by ice and snow and breaking up every year like ours! ..."
Wed Jan 29 2014 11:52am |
Lol - Yes was thinking from experience of our visits to the sunny West Coast & Las Vegas Sema i guess.
Wed Jan 29 2014 12:23pm |
Thanks for your help Hawke makes it a bit clearer You learn everyday |
Wed Jan 29 2014 4:32pm |
Site sponsor and online seller of Range Rover Styling accessories and HAWKE Alloy wheels.
Wed Jan 29 2014 4:50pm |
