![]() | Home > Technical > alarm and central locking query |
Is your model a keyless ignition? |
Yes. It is usually a faulty door latch. The electric motors driving the lock/unlock become weak and don't complete the locking action.
jon2014 Member Since: 08 Jan 2014 Location: london Posts: 13 ![]() |
Yes ady is keyless ignition |
Tks paddi. If this is the case wd it be xovered under warranty? |
Once you have locked your door, take the key fob out of range approx 1m +. Leave the key fob out of range and then try the door again. I suspect the door is opening because the fob is still in range. Which it is designed to do. |
Ha ady. I left it 20m away and tried the door . It still opened.
As Paddi surgests then, faulty door latch. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Had my drivers door latch changed today.
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 ![]() ![]() ![]() |
How do you know which lock has failed? ? 2010 RRS HSE 3.0 tdv6 2010MY
Like I said in the post, the small black tab under the lever was sticking out a bit on the drivers door. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
The lock that has failed will be on the door that you can still open by pulling the external handle after the central locking activated and alarm set. 2008 MY Java Black TDV8 HSE
Found it. The front passenger wasn't locking sprayed some wd40 in it and seemed to work....that was in the drive anyway went out today, parked up and yeah...It wouldn't lock
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
TOP TIP: avoid the inconvenience of door latch repairs by exiting your RRS through open windows thus reducing wear on the mechanisms. I never saw the Duke brothers having to fix theirs, so it's tried and tested. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
johnb8538 Member Since: 04 Aug 2015 Location: Glasshoughton Posts: 24 ![]() ![]() ![]() |
After spending a few nights wondering how to resolve this I tried your guidance and it worked great. A temporary fix of course as the actuator has clearly failed but at least I can go to sleep at night now. Many thanks. |
