Home > Technical > alarm and central locking query |
Is your model a keyless ignition? |
Mon Jan 27 2014 10:29am |
Yes. It is usually a faulty door latch. The electric motors driving the lock/unlock become weak and don't complete the locking action.
Mon Jan 27 2014 10:32am |
jon2014 Member Since: 08 Jan 2014 Location: london Posts: 13 |
Yes ady is keyless ignition |
Mon Jan 27 2014 10:50am |
Tks paddi. If this is the case wd it be xovered under warranty? |
Mon Jan 27 2014 10:52am |
Once you have locked your door, take the key fob out of range approx 1m +. Leave the key fob out of range and then try the door again. I suspect the door is opening because the fob is still in range. Which it is designed to do. |
Mon Jan 27 2014 10:55am |
Ha ady. I left it 20m away and tried the door . It still opened.
Mon Jan 27 2014 11:28am |
As Paddi surgests then, faulty door latch. Should be covered under warranty, mine was. |
Mon Jan 27 2014 12:33pm |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 |
Had my drivers door latch changed today.
Wed Jul 02 2014 8:18pm |
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 |
How do you know which lock has failed? ? 2010 RRS HSE 3.0 tdv6 2010MY
Sun Jul 13 2014 8:48am |
Like I said in the post, the small black tab under the lever was sticking out a bit on the drivers door. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Sun Jul 13 2014 11:57am |
The lock that has failed will be on the door that you can still open by pulling the external handle after the central locking activated and alarm set. 2008 MY Java Black TDV8 HSE
Sun Jul 13 2014 12:38pm |
Found it. The front passenger wasn't locking sprayed some wd40 in it and seemed to work....that was in the drive anyway went out today, parked up and yeah...It wouldn't lock
Sun Jul 13 2014 11:11pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
TOP TIP: avoid the inconvenience of door latch repairs by exiting your RRS through open windows thus reducing wear on the mechanisms. I never saw the Duke brothers having to fix theirs, so it's tried and tested. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Fri Jul 18 2014 6:04am |
johnb8538 Member Since: 04 Aug 2015 Location: Glasshoughton Posts: 24 |
After spending a few nights wondering how to resolve this I tried your guidance and it worked great. A temporary fix of course as the actuator has clearly failed but at least I can go to sleep at night now. Many thanks. |
Tue Aug 04 2015 8:22pm |
