Home > General > Advice buying 4.2 V8 SC |
Woolmeister Member Since: 30 Dec 2013 Location: Kent Posts: 10 |
This is a great guide for the TDV6 and TDV8 so should get you started....
Wed Jan 22 2014 10:45am |
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 |
Hi there...
Wed Jan 22 2014 11:29am |
alcarmichael Member Since: 21 Jan 2014 Location: Reading Posts: 9 |
Thank you for the link - unfortunately I can't open the file on this computer but will definitely have a read when I get chance.
It's a 2007 HSE with 60k on the clock. What would you say was the going rate for this spec/year/mileage? I hadn't come across your threads until now (like I said this forum takes an age to load for whatever reason out here), I just searched all the posts you've made on the forum and have just finished reading the ones I chose to read since you commmented. Yes, that's how long it takes for pages to load!!! You've certainly done a lot of research before buying, the information posted should in turn help me |
Wed Jan 22 2014 3:32pm |
Wed Jan 22 2014 3:39pm |
I've just tried to pm you but seems I need 3 posts to do so. Here is another one |
Wed Jan 22 2014 4:46pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Hey pal... Stay safe in Afghan....
Wed Jan 22 2014 11:26pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
HDC errors can also be caused by blown brake bulbs. This is because the HDC will light the brake bulbs as part of its operation. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jan 23 2014 12:25am |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
my 2p worth, from experience
Thu Jan 23 2014 11:08am |
I shall try and post again! For some reason it takes approximately 15 minutes for a page to load on this site out here!!!
Fri Jan 24 2014 10:05am |
Forgot to post this:-
Fri Jan 24 2014 10:50am |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
Why are people so looking after a FSH!!??
Fri Jan 24 2014 1:39pm |
I'd NEVER buy without knowing it had been properly serviced and regularly.
Fri Jan 24 2014 3:21pm |
the bushes are about £10-£15 each, front and back, top and bottom, the wishbones approx £150 each (upper) and I got a local mechanic to replace at cost of £200.
Fri Jan 24 2014 4:20pm |
Well I've just checked back on to the Sterling Performance site where the car is advertised, it has today lost 30,000 miles and gained 4,000 pounds!
Fri Jan 24 2014 4:46pm |
