![]() | Home > General > Advice buying 4.2 V8 SC |
Woolmeister Member Since: 30 Dec 2013 Location: Kent Posts: 10 ![]() ![]() ![]() |
This is a great guide for the TDV6 and TDV8 so should get you started....
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 ![]() ![]() ![]() |
Hi there...
alcarmichael Member Since: 21 Jan 2014 Location: Reading Posts: 9 ![]() ![]() |
Thank you for the link - unfortunately I can't open the file on this computer but will definitely have a read when I get chance.
It's a 2007 HSE with 60k on the clock. What would you say was the going rate for this spec/year/mileage? I hadn't come across your threads until now (like I said this forum takes an age to load for whatever reason out here), I just searched all the posts you've made on the forum and have just finished reading the ones I chose to read since you commmented. Yes, that's how long it takes for pages to load!!! You've certainly done a lot of research before buying, the information posted should in turn help me ![]() |
I've just tried to pm you but seems I need 3 posts to do so. Here is another one |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Hey pal... Stay safe in Afghan....
HDC errors can also be caused by blown brake bulbs. This is because the HDC will light the brake bulbs as part of its operation. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
my 2p worth, from experience
I shall try and post again! For some reason it takes approximately 15 minutes for a page to load on this site out here!!! |
Forgot to post this:-
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
Why are people so looking after a FSH!!??
I'd NEVER buy without knowing it had been properly serviced and regularly.
the bushes are about £10-£15 each, front and back, top and bottom, the wishbones approx £150 each (upper) and I got a local mechanic to replace at cost of £200.
Well I've just checked back on to the Sterling Performance site where the car is advertised, it has today lost 30,000 miles and gained 4,000 pounds!
