Home > Maintenance & Modifications > TDV8 MAP sensors clean |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 |
Did mine two weeks ago. Quick and simple to do. Just 15 minutes or so.
Mon Nov 18 2013 11:53pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
my mpg has drastically dropped with no change to driving style at all. averaging 17mpg if lucky.
Sun Nov 24 2013 2:02am |
Yep, that's the stuff. Don't use anything else.
Sun Nov 24 2013 10:37am |
My rear anti roll bar is leaking and needs to be replaced. This was spotted 3 months ago but I couldn't afford to do it. :/wonder if that has gotten worse and is affecting mpg 07 TDV8 + BAS map |
Sun Nov 24 2013 11:05am |
Yep. That is what I used too. |
Sun Nov 24 2013 1:07pm |
Unlikely its the leaking ARC bar. Check the easy things like tyre pressures and dragging brakes. After a run feel the wheels (not the discs) and if one is warmer than the others that would indicate a binding brake. When was the air filter last renewed? An inexpensive easy DIY job. Remember that colder weather can affect fuel consumption as the FBH uses a bit and switching on screen and seat heaters means the charging system draw more power from the engine. 2008 MY Java Black TDV8 HSE |
Sun Nov 24 2013 5:28pm |
I would put it down to the colder tempreatures for the drop in mpg, using more electrics, taking longer for your vehicle to warm up etc etc. |
Sun Nov 24 2013 7:00pm |
Sun Dec 22 2013 1:29pm |
I think this is it, cold weather. Otherwise can't explain the sudden drop. We're talking about going from getting 330 miles a tank to 250 - for the same kind of driving 07 TDV8 + BAS map |
Sun Dec 22 2013 1:33pm |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
These sensor are diferent from TDV6 ones, the TDV6 seem to have a hole and no electrical thingly is seen. The photos of the TDV8 sensors posted seem to be temperature sensor and MAP combined. there are more wires in the plug, TDV8 have 4, TDV6 have 3, related to 1 more values to control (NTC for temp). see:
Tue May 13 2014 10:04am |
