Home > Maintenance & Modifications > TDV8 MAP sensors clean
TSLJon
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
88k on it now mate.
Did it at 86500 roughly.
Basically decarbons the engine. Was impressed. 2008 Range Rover Sport TDV8 HSE
2013 Range Rover Sport TDV6 HSE 8 Speed
Post #384312 Thu May 30 2013 8:29am
TheDB
Did mine two weeks ago. Quick and simple to do. Just 15 minutes or so.
Sensors looked clean. Gave them a good spray with Carb Cleaner regardless.
Responsiveness of the engine has marginally improved and it looks like mpg is up by 1mpg.
Pleasantly surprised.
Post #402780 Mon Nov 18 2013 11:53pm
jack.bauer
my mpg has drastically dropped with no change to driving style at all. averaging 17mpg if lucky.
i noticed this coincided with me making the switch to shell v-nitro which is even more confuing Question
been on nitro for about 5 full tanks now. using the millers stuff each time.
going to try cleaning these sensors. is this http://www.halfords.com/webapp/wcs/stores/...yId_255221 what i need 07 TDV8 + BAS map
Post #403422 Sun Nov 24 2013 2:02am
Paddi
Yep, that's the stuff. Thumbs Up Don't use anything else.
Worth a try but it sounds as if you may have a problem with something else. 2008 MY Java Black TDV8 HSE
Post #403436 Sun Nov 24 2013 10:37am
jack.bauer
My rear anti roll bar is leaking and needs to be replaced. This was spotted 3 months ago but I couldn't afford to do it. :/wonder if that has gotten worse and is affecting mpg 07 TDV8 + BAS map
Post #403439 Sun Nov 24 2013 11:05am
TheDB
Yep. That is what I used too.
Post #403448 Sun Nov 24 2013 1:07pm
Paddi
Unlikely its the leaking ARC bar. Check the easy things like tyre pressures and dragging brakes. After a run feel the wheels (not the discs) and if one is warmer than the others that would indicate a binding brake. When was the air filter last renewed? An inexpensive easy DIY job. Remember that colder weather can affect fuel consumption as the FBH uses a bit and switching on screen and seat heaters means the charging system draw more power from the engine. 2008 MY Java Black TDV8 HSE
Post #403457 Sun Nov 24 2013 5:28pm
I would put it down to the colder tempreatures for the drop in mpg, using more electrics, taking longer for your vehicle to warm up etc etc.
Post #403468 Sun Nov 24 2013 7:00pm
jack.bauer
63k. Looks fine to me? Require a clean much?
https://www.dropbox.com/s/fkiohkumr67kk8r/IMG_20131222_131105.jpg 07 TDV8 + BAS map
Post #406980 Sun Dec 22 2013 1:29pm
jack.bauer
I think this is it, cold weather. Otherwise can't explain the sudden drop. We're talking about going from getting 330 miles a tank to 250 - for the same kind of driving 07 TDV8 + BAS map
Post #406981 Sun Dec 22 2013 1:33pm
CUCO
Spain
Re: TDV8 MAP sensors clean
Paddi wrote:
These sensor are diferent from TDV6 ones, the TDV6 seem to have a hole and no electrical thingly is seen.
The photos of the TDV8 sensors posted seem to be temperature sensor and MAP combined. there are more wires in the plug, TDV8 have 4, TDV6 have 3, related to 1 more values to control (NTC for temp).
see:
Post #424130 Tue May 13 2014 10:04am
